Colloidal Silver Water
Started by zenmountain, June 13, 2009, 01:10:42 PM
raburgeson
There was a article on the net to use a car battery. Never hook to a car battery. The posts are lead.  Use a plug for the cigarette lighter instead and two caps charged in series to take of your about 27 to 30 volts. You might have to have the engine running and use charging voltage to get your voltage right. Watch the water you use. If the water or silver wire become discolored your source for distilled water is putting minerals back into the water. This colloidal system is good for checking water, if they put minerals in they might have included Fluoride. These minerals will poison your silver wire. The point of buying .9999+ wire is to keep other minerals out of your water. You don't want to plate those minerals to your positive wire. I recommend getting a tester and keep it between 15 and 20 ppm. Also you can use the tester to test an unknown water source, good water will read zero. Anything real close is acceptable. Listen to the man that has been making it for 6 years. Don't turn blue like the guy that doesn't listen to anybody. Check out the blue man hoax video. There are people on the net that have used colloidal silver for more than 15 years and they show no sign of discoloration.
Yes you caught me, I make the stuff too. When my oldest son and family moved in we had some trouble with mold in the bathroom from too many showers. I literally shot the walls with a paint gun to get rid of it. I got soaked doing it and did not turn blue. It was a Campbell Hausfeld general purpose spray gun # DH3800. On my back I have even used a cat dropper to inject silver water into my sinuses to clear them up. It worked fine but, when that nasty crap dies and drains you go though hell.
At the time I was wondering if humans can get white nose syndrome that's killing the bats. We don't hibernate and blow our noses. They are mammals too.
raburgeson
Double post, I had to split this up. I have a box that has 3 rechargeable batteries in it. This is not the way to go. I also have a DC power supply. You get tired of tearing the box down to recharge the batteries. I don't make that much, there is only 2 of us using it. A pint every couple of days in a mason jar. Very rarely I can get 3 pints out of a charging session. Usually I only get two. You can see where that will wear the Phillips heads out on the case screws. If you get 12 gauge wire you will notice coax fittings do not except it well. I used a 15 amp receptacle with the push in locking holes in the back. It works for 14 gauge too. I drilled holes in the right place on the case and simply super glued it to the case. I used a drill large enough to allow a small screw driver to unlock the silver wire. The three terminals in series are simply screwed to the positive and negative sides of the receptacle. I can lock in 16 to 12 gauge wire. I prefer the DC power supply.
I bought a Frigidaire piece of crap air conditioner. It's the best bacteria farm I have ever seen. I spray colloidal silver into it often. I really need to replace that junker. This is my third year fighting with it.
bolt
Use an old laptop charger everyone has one some where. They are all around 19v perfect voltage then stick a  1k resistor  in series.  Clamp the silver rods to a strip of terminal block with the series resistor one end then drop in to glass of pure water.
Silver is excellent for conditions that it needs to come in direct contact, skin problems, throat, mouth, ears, bad breath, sore gums, athletes foot, burns, colds, flu, and some stomach  bugs but not all.  Its pretty effective for chest infections using an inhaler or vaporiser. Its also a good kitchen and bathroom cleaner i use any spoiled batches for external cleaning use.
For powerful systemic body "cleaner" use Chlorine Dioxide MMS will deal with everything else silver can not reach and therefore not very effective. A few drops of MMS will clean out ALL your pipes LOL
I thought i add that for people with life long illness deemed "incurable" and only manageable by mainstream the person has to go thru several stages.
DETOX heavy metal chelation using betonite clays and zeolite
DIET changing to a green diet is essential for correcting life long problems especially in the short term is needs to be extreme till problem fixed then very slowly introduce other foods. Diet must be void of ALL animal products, no meat, cheese, eggs, milk, pies and pasties, no pizza, fries and other fast food products. If its not fresh plant food you cant eat it.
CLEANING use MMS, ozone therapy, beck blood cleaners, zappers and pulser to rid the body of long term parasites, infections, viruses and fungus.
PURGING  Drink only pure water like 5 stage reverse osmosis water and drink at least 4 pints a day of water only. Bottled water and city water is only just about potable just about passing government regulation  and certainly no where near good enough for sick people.
Minerals and Vitamins.  While everyone has their favourite herb and spicy formula they really are not very good converting a sick person back to full health but can only assist in staying healthy. However a bad diet can not be made good by ANYTHING other than a GOOD diet.
There are a few exceptions. 95% of people are now severely iodine deficient.   Your body NEEDS iodine it can not function properly with out it.  I also suggest 1 or  2 grams of vit C per day (EXCEPT when taking MMS) and  5000 IU of Vit D3 (sunlight in a bottle).  You should also eat a teaspoon of KELP per day contains just about every mineral and vitamin on the planet in natural form. High dose mega vitamins and artificial minerals from your pharmacy are not very good at all and in many cases can do more harm then good.
oroshay
Hello, just an update for you... (see my previous posts)
I have now been taking CS for about two years, and I must say it is the best medicine my wife and I have ever taken.
About a year ago now, we took the step of installing a Reverse Osmosis unit under the kitchen sink, for our pure water supply. We are both healthy and when a cold comes along it is gone the next day, and we have still not turned blue!
I have not bought any more silver rods since building it so it has cost me virtually nothing to produce CS for us. The silver rods seem to last a very long time.
Best regards, oroshay
raburgeson
I had to water board myself again. We get the heaviest chemtrails in the country here. If there is a blue spot in the sky I can take a picture of them spraying it, matter of fact I have many on my camera right now. Anyway I have a cat (animal) medicine injector and when my sinuses get loaded up I tilt my head back over a pillow and inject about 3 CCs of colloidal silver in each nostril. If there is an infection present you will feel pain.
Personally when I do this I feel muscles in my forehead relax and then the rest of the body relaxes. I'm not sure what it does but, it does it well. I have to stay on my back head tilted back about 10 minutes to give it time to get all the way up into my sinuses. I have been drinking it 15 PPM for about 6 years, no bluing, feel great. I am due to buy more silver, it does last a long time but, not forever.
