do you like this topic?
 no, it is BS
david lambright
an email:           Hi, Dave,
I finally got the tools and a galvanized pole. I cut the pole and bent the pieces to fit around my circle of plastic counter top material. I was wondering how much contact each piece needed. Right now some have contact the entire length from top to bottom and others vary. For instance, one section the pieces only contact at the top. The device will still energize like a pmh should but i fear that i dont have enough contacts to create a good working model. Please give me your opinion. I would really hate to take it apart unnecessarily. This project was very work intensive for me.  When I was experimenting with it and recording, I used a large calcite crystal I had found a few years back.  It seems as though the aura had a stream coming from the stone in kind of a whirling motion towards the generator. I can describe the aura itself as the same as if i let the gas out of a lighter, in that, it was a very subtle and translucent and it distorted the light reflecting through it in the same way the gas does. This made it impossible for my camera to record and for me to view later. I tried putting a window screen in front of the point of view of the camera as well and my camera simply isn't high quality enough coupled with an old tube television I have to review my videos. I thing that a new flat screen would actually clear up some of the distortions caused by this old T.V.                             Thanks for your inspiration Dave McTavish
sm0ky2
Hi Dave,
My advice, to mr McTavish would be to examine the points of contact very carefully.  ANY contact at all will be able to produce the effect, but in order to get the most output possible, i have found its best to make sure the point of contact are all in a relatively straight line
i.e. if some only contact at the top, then make sure they ALL contact, at at least the top.
ideally, you want the most surface area of contact possible, but if its too much to actually "do", then try to make sure you have a parallel line traveling around the circle.
  Glad to see youre still interested in this effect.  I cant wait until someone figures out how best to interact with the substance we are seeing.
            Sm0ky2
sm0ky2
an afterthought.......
IR-transistors can be set-up to detect the presence of infrared light.
and although i believe this emmission to be slightly lower frequency than IR, i think it still may interact with the transistor....
perhaps if someone can design a makeshift "IR detector", that simply turns on a LED in the presence of IR light.
then take one of your devices into a dark room, and give it a go.
david lambright
i will have to agree with smokey, whenever i use my camera around my devices, it seems that the IR focus does not work right. i am still trying to find the right kind of FLIR camera. the gas finder series i believe is what am looking for....david
david lambright
suggestions?
i am trying to find someone in my area, with a gas finder series FLIR camera. they cost in the 10s of thousands, i just need to image my device first, if there is anything interesting, get a recording of it. i would like any suggestions....thanks, david
