My first H2O splitting experiment
Started by gast, September 01, 2005, 04:53:30 AM
Markus
Another possibility for generating the wave form is to use a program like Goldwave (http://www.goldwave.com/). There you can design your own wave forms using mathematical expressions. That?s very good for experimenting. The frequency and max. output voltage will be limited by the soundcard of your computer. (usually ~ 20kHz / 2V). But increasing the voltage isn?t a problem. There are many amplifier circuits that can be used for this.
I?m not sure if using special wave forms for water electrolysis can lead to overunity.....Stanley Meier used also special geometry and there are a lot of people, even Gene Mallove how claimed he was a fraud.
Good luck, anyway.
Quote from: Gast on September 01, 2005, 11:29:41 AM
Stefan, thanks for the infos.
But to go for sure (I don't know the voltage curve of an inverter in the moment? ;)):
I think you mean this a) or maybe this b)
a)? ? /|? ? ? /|
__/? ? |__/? ? |__
b)? ? /\? ? ? ? ? /\
__/? ? ? ? \__/? ? ? ? \__
No, I mean a stepwave ! Like going up in steps ! Like a sawtooth, but in steps stepping up the ramp !
Regards, Stefan.
gast
@ Stefan: Okay, I think I got you now...
        _        _
      _| |     _| |
    _| | |   _| | |
___| | | |__| | | |___
@Markus: Using an audio editor for creating the wave is a good idea.
But I think this experiment requires a good monitoring of the waveform. But unfortunately I don't own an oszi.
Markus
I suggest you buy an oscilloscope. You can find them used and cheap on ebay.
Before you do experimental research you should have the needed equipment.
You will also need it to calculate the efficiency of your electrolysis.
@Gast
yes, this is now the right waveform.
Try to get a scope first.
Regards, Stefan.
