Safe One Wire energy transfer by Serbian inventor Milutin Miletic
Started by hartiberlin, June 16, 2011, 11:51:28 AM
Shokac
To communicate over a single wire 5kW, not the equipment is put in a plug.
This video has nothing to do with Milutinov invention.
This video is nothing but a Tesla coil in the primary and secondary. On the other hand to use ground, which in turn leads us to the "two" wire
Milutin use something very simple and has a specially crafted string.
T-1000
Quote from: Earl on June 30, 2011, 12:41:36 PM
I just stumbled onto a video concerning a Russian one-wire transmission.
http://www.youtube.com/watch?v=ZckaMOlixqw
Regards, Earl
This guy who posted video is Lithuanian ,same as I :) And because Lithuania is neighbour with Russia many guys speak and understand Russian as secondary language...
Quote from: Shokac on June 30, 2011, 02:56:12 PM
Not true, you can have not grounded system in receiver as 1 wire ends with 2 diodes splitting current into positive and negative. Try any HW transformer system from not grounded battery with spark discharge and you will see what it is all about. As long as you have HV discharge, it creates circumstances where there's electrical dipole between human/ground and any wire in system.
Cheers!
T-1000
Shokac
Quote from: T-1000 on July 01, 2011, 10:03:31 PM
Cheers!
T-1000
Yes, but only in HV circuits and spark gaps. Milutin use only 220V?!?!?
IotaYodi
QuoteYes, but only in HV circuits and spark gaps. Milutin use only 220V
High voltage is a loose term. Anything over 50 volts has enough current to set the heart into fibrillation. 90 to 120 volts can be considered to be high voltage.
A spark gap doesnt have to ionize the air to where you visibly see it. The most intense magnetic field intensity off a pulsed dc spark gap is very low voltage. I think its below 3 volts. This has been confirmed by scientists. A high voltage spark gaps magnetic field intensity is much lower.
There are 4 wires coming into the plug from the main. The main is single phase. You can have 2 circuits on one neutral. Yet from the looks of the plug there are 2 neutrals. Even with a 2 pole breaker you only need one neutral. So does that mean there is a separate neutral from the neutral bar to the plug? Would one of the 3 wires actually be a twisted bifilar or bi metal for the other neutral?
What I know I know!
Its what I don't know that's a problem!
totoalas
Quote from: totoalas on June 29, 2011, 08:53:03 AM
One Wire energy transfer  Variant
Quest for the material  begin
cheers
totoalaS
http://www.youtube.com/watch?v=dKBhN64hdp4&feature=mfu_in_order&list=UL
Hi to all
NOW IT SAFE TO TOUCH LOL
using Neutral plus heating element(no connection)... will light up a 220 v acneon
No ground connection needed
Material
Live and Neutral 2 mm magnet wire
Ground 1 mm magnet wire no connection
Heating element 0.5 mm wire
neon lamp 220 v
Power source 220 v ac 50 hz Line neutral
cheers
totoalas
http://www.youtube.com/watch?v=lE0oq3XWOWY&feature=mfu_in_order&list=UL
