Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
fritz
Quote from: conradelektro on June 30, 2011, 09:14:16 AM
First I was very enthusiastic, but after some long reflections this morning and considering what I know about Austrians (being an Austrian myself) I get some very skeptical feelings.
At least he is not from "Linz".
Otherwise if the outer pyramid construction influences the outcome only by a small degree - why should there be any reason to weld pyramids over and over if you have limited space.
In 2006 it was magnets
The "copymark" secret with the magnet was already exposed years ago.
now it is quartz sand filled in a strange way which does the trick. This does not give me confidence.
What gives you confidence ? A small signal transistor (selected out of 150pcs from conrad) operating in avalanche mode connected with 16 crocodile cables measured in undersampling math mode on a tek scope? gg.
Even if this type of equipment can be found in almost any Austrian attic (CB+"Billigziegel) -
the other option of using an iginition coil - should be not that tricky for the average replicator.
Just start your car with one sparkplug disconnected ;-)))
The inventor should invite you and show you several working pyramids. That would be full disclosure. I guess it would not matter to you whether it is "over unity" or "power harvesting from nature".
(...) the inventor should invite you for a 6pack of beer and show you his series production line....
I think he is definitely bored of that way of disclosure.
Anyway - I  know some places with certified waterlines - so the overall effort shouldn´t be that much - the material used is cheaper than a solar panel with similar power. So I will build one this summer.
The "soup" on his V6 instructions was definitly to thin for me starting a construction project.
Now I have the feeling that the construction secrets are almost clear - and the construction principles are somewhat consistent.
What concerns the "wire" used it would make sense to use the same brand... because this type of wire has no specified dielectric property.
rgds.
I think this is no fake.
Why should he do it like this ?
From all the videos you see, that he is really into pyramids and
that the old system was bought out by a big company, so he wanted to make money
with it.
I don´t see any reason for faking it.
He would make himself a real fool, if it would come out, that this is a fake.
And please no bad comments about the cothes of any user...
We will see, if somebody can replicate it.
He said to me, there is a guy that has a 3.8 Meter big pyramid
and I am already anxious to see his results.
Regards, Stefan.
NerzhDishual
Hi OU Dot Com Guys,
Just my2cents.
I do not "feel" that this guy is a fake. To me, he is honest.
Of course, I can (must?) be wrong as I was too gullible with some other devices (this bl' f' alleged-self-running-on-cap-only "Window Motor", for example)...
Logically speaking: usually the con men are (were?) more "expeditious" and do not spend too much time making up their traps.
Now, to divert people from the right path, incite them to spend time and money and, finally, discourage them; some individuals (agents?) can (have to?) be more 'patient'...
Is it because "OU" is coming in plain sight?
The "Pyramid Man"'s device is a mix of:
1) Pyramid stuffs (claimed (and proved?), notably, to be able to maintain razor blades sharp without the auxiliary source of energy ; see: Karel Drbal, Prague, Patent Number 91304). OK.
2) Way of assembling coils a la DANIEL MCFARLAND COOK (patent US119825 -  Oct 10 1871).
3) Kinda way of building permanent magnets or (permanent also) electrets.
4) fuzzy 'Lost Science' stuffs (G. Vassilatos (a good book however, IMHO)).
Any-way I will not try to reproduce this device because:
1) I have no 20 watts CB amplifier. It is slang called a "slipper" and is forbidden in France.
2) He did not specify AM or FM.
Yes, I'm kidding. :P
So, finally, I do not know what to think about this device...
1) Is it genuine?
2) Is "Pyramid Man" a kinda "Electric Man" (sounds not):
http://www.youtube.com/watch?v=pY745NxZwsY
3) Or, is he another Daniel Pomerleau?:
http://peswiki.com/index.php/Directory:Daniel_Pomerleau_Free_Energy_Coils
Very Best
PS : you know what?
An 'OU' electric unit is fine, but still rare and kept secret. Is-it not?
A Diesel Generator that runs of water alone (HHO) is *absolutely not* out of reach. Indeed; it is noisy but just noisy.
What about this boat with a 500 HP engine that runs on sea water only? :
http://translate.google.fr/translate?sl=fr&tl=en&u=http%3A%2F%2Ffreenrg.info%2FHydrogen%2FMIG_675%2F
In French : http://freenrg.info/Hydrogen/MIG_675/
a.king21
A new circuit by Patrick Kelly really works and it's true free energy. It's by an unknown Danish Developer. It's on chapter 7 page 8 of his free PDF book.  I suggest we all get into it and maybe figure out how to tune it to get more power. I recycled the components from 2 cfl's to make the circuit.
I use aluminium foil for the aerial. It works.
I promise you that you won't waste your time with this one.
It's worth developing.
