Trawoeer Power Pyramid Version 12 - Electrical output from a homemade pyramid
Started by hartiberlin, June 28, 2011, 04:05:30 PM
DiegoPalma
Hi @Thomas and all enthusiastic researchers of free energy in this forum.
My name is Diego Palma from Peru (Cusco). I have been following with a lot of interest the forum and making my own attempt of building a replication of Thomas pyramid.
I know little about electronic or dowsing but I have a good common sense and criteria.
I am writing to this forum to ask you and Thomas all the help you can give me to make this experiment work. I will try to be very specific in the details so all would be very clear.
I want to express my full respect to Thomas and his open attitude of sharing openly his knowledge and discoveries on free energy. I hope the world would benefit on this shared attempt to replicate his experiment and improve it in an open source arena.
Pyramid
So, I started with the pyramid with 8 square iron bars (2cm x 2cm x 100cm), all welded.
I used 3 Gypsum / Dry wall plates of 10mm. (I couldn’t find the 19mm used by Thomas and hope it is not so important).
Inner coil of reactor
For the inner coil of the reactor I used 10mm x 360mm copper tube.
I dig the two 5mm holes at 35mm from the bottom and 40mm from the top.
Distance between holes is 285mm. All measures from the center of the holes.
For the outer tube of the reactor I used a 29mm x 305mm copper tube, and two reductions I make from a solid 29mm copper tube.
All copper materials are well cleaned and polished as he suggested.
The reductions are 10mm width (5mm goes outside the outer tube and 5mm gets inside the tube) with a 10mm hole in the center.
I welded the reduction to the inner tube at 20mm of the bottom and 5 mm from the center of the hole.
DiegoPalma
For the inner coil I used 16 AWG cable with 1.5mm copper and 3mm total width including insulation.
I used 97 windings as suggested initially by Thomas.
The 97 windings fit exactly around the 280mm between the two holes.
The center of the inner coil (reactor) is at 182mm from the top of the reactor.
Note: As I mentioned before, for the outer tube of the reactor I used a 29mm x 305mm copper tube. I know Thomas mentioned a 290mm large copper tube instead. I initially used a 290mm large tube but it do not fit since the reductions Thomas is using add more length to the outer tube (around 20mm) and the ones I use are only 10mm wide each.
I would like to ask Thomas if this is correct.
Finally, I checked the cable conductivity and isolation from the copper tube (no short cuts present).
Outer coil of reactor
For the outer coil I used a 42mm x 308mm plastic tube and two proper plastic lids.
I winded 96.5 windings of the 16 AWG 1.5mm cable (same direction).
FreeEnergyInfo
Quote from: DiegoPalma on July 26, 2011, 01:25:03 AM
THANKS...
DiegoPalma
Capacitor
For the capacitor I used a 20mm x 525mm plastic water PVC pipe with two coils of 11 meters each of the 16 AWG 1.5mm copper cable. I add 10cm to each endings on both coils to connect and synchronize the capacitor.
I cut the endings and mount it in the pyramid to keep the reactor in the exact center of the pyramid as Thomas indicated.
Charging the reactor
The voltage in my country (Peru) is 220v. Here comes the tricky part. I decided to go for the high voltage charging instead of the High Radio Frequency way since my understanding of electronic and RF is limited. I found a high voltage DC transformer made from a fly-back. It makes 20,000 volts (that’s what the seller told me but I couldn’t prove it). I bought a multimeter and there is a warning to do not attempt to measure a circuit if the voltage is grater than 60v DC so I do not know neither the exact amps that are coming out of the transformer, but when I bring the terminals closer than 30mm they make a nice flow of lightning current between (sorry for my English).
I went to a swimming pool service and found two different brands of filter quartz sand. One is Crystaline Silica from Southern Products Silica C.O., INC (first picture) and the second one is a Peruvian brand (more expensive) and is made of ground quartz (second picture). I bought both.
I am going to use the first one since it is more similar in color to what Thomas showed in his video. (The second one is white and irregular in size but I have a 1.5mm frame to filter it if necessary)
That’s all for now. I will wait for your suggestions before going into the next step.
I read that the transformer need to be AC output and between 3 to 7 kilovolts but I have read different approaches and changes of mind in the last days that I am not sure anymore. I hope Thomas can give me the right approach.
Thank you Pascuser for the dowsing articles I would studied them and applied them in my yard. I live in Pisaq, a small town in the Sacred Valley in Cusco (2 hours from Macchu Picchu) at 3,000 meters high (11,000 feet aprox) and  and there is a lot of water underground.
I hope Ben, Matsatbg, Smoky, Pascuser, Duff, Jimboot, Neptune, me and all the rest together can replicate the power pyramid soon with the help of Thomas.
Waiting for your comments...
Diego
madsatbg
Hi DiegoPalma,
Greetings to distant Peru.
Congratulations, you did an excellent.
Would you share what voltage obtained after loading the "raektor"?
This is the first test operation of the pyramid.
regards   madsatbg
