Jack Noskills
Coils are from identical transformers.
Center is sideways. As it is rectangular the core is first filled up there but still leaving empty space in secondaries. Then you just loop secondaries together. Broli's excellent 3d picture shows this nicely.
In my test setup 15 mm * 15 mm of iron is shared between all coils and 15 * 12.5 mm is shared only between secondaries. The size of hole in my coil was 15 * 27.5 mm.
If you have any kind of rectangular coils you can use them. The effect will be there, only power will be different. It is important to have lots of turns in the primary so you need to use as little input current as possible. We are only interested in the magnetic field, the electric company may keep its expensive current lol.
penno64
Thanks Broli,
I guess I should have worded my question better.
The lighter colour in you magic 3D, needs to fill the centre coil (primary) only, but
the outer coils (secondaries), need to have both the outer limbs of the  "E" and the Rectangular
cores through them.
I guess that why I was asking if the coils are identical.
Regards and Thanks, Penno
Sorry Jack, I was typing this post when you responded. I will leave it here anyway
and thank you, you have answered my question - precisely.
Kindest Regards, Penno
JouleSeeker
Quote from: CLaNZeR on August 08, 2011, 04:46:00 AM
I Have added pictures that Mavendex kindly sent to an Album on my site.
Various coils and progress.
http://www.overunity.org.uk/album.php?albumid=246
Good stuff David !
Cheers
Sean.
Beautiful work and photos.
It appears that you have an inner (secondary) winding of approx 16 AWG red wire, then thicker yellow wire, THEN the "exhaust donut" and then a THIRD winding of red wire...
Is that correct?  why THREE windings?  I thought just two were needed.
Also, is the "exhaust donut" from that place in Nebraska mentioned earlier in this thread (or where)?
Thanks for the photos -- very impressive work.  I hope it works!
importfanatik
This is good stuff guys but it is clearly related to BiTT, and not the gabriel device.
can you move your discussion to the BiTT thread here?:
http://www.overunity.com/index.php?topic=7833.255
Thanks!
Mavendex
It works to the fact that a 0 powerfactor can be reached, you can wind down the primary to make that happen or input lots of amps with less turns on the primary.
The donut is made out of L&S and the yellow wire was just to fillout the space its all 16 awg but the yellow wire is insulted and is 10 awg with the insulation.
Ive been looking at the 98% efficient transformers the Z.B.D. and some of them are closed core which is interesting.
If it didn't cost so blasted much to have new tooling created getting that outer shell closer to the inner core would probably increase efficiency. which is another reason why Im opting to have the shell made out of Permalloy this next time around. then if we can get better results Ill have another made with new tooling. Wish I had like 10k all at once so I could just do this without having to scrimp and save to have stuff made but oh well all in good time.
