0 Members and 17 Guests are viewing this topic.
Hope
Goldmine electonics has that perma foil
www.goldmine-elec.com/
Update on CLETUS HOWELL     -  Just after he floated a rock and was barred from the forum he was found dead and his files all erased.  RIP Prince of Meshack (MyHouse).   He has physical shapes doing what we all still can't do.  His brain infection made it hard for him to communicate with us all.
Magluvin
Hey Mav
Ahh 50g each.  ;]  Like 3 oz.   Seems like some powerful stuff if it can make 1 gal of strong fluid.  Water mix?   Normal ferro fluid is oil.
From my experience, say if you mix glass micro bubbles(thickener) to resin, it is highly recommended that you mix the 2 parts epoxy first, then add the bubbles or powder.  Probably table top resin, or surf board resin. With a lot of material added to the resin, the cure time will probably go up because the material will absorb the heat from curing, so it will take longer.
This regular jb takes a while to even stiffen up. The quick is too fast.
I ran a large brick magnet in the bead blaster at work and got some nice iron powder to add to the mix im rollin over here.  Im finishing up painting the wires tonight using a flexible primer{SEM can). Ive got at least a couple of grams of iron dust.
Im not feelin real confident on this wire concoction, thinking there is something better out there.  ;] But I shall STICKy to it as im interested.
Mav, do you have a link to the stuff so I can get a gander at what they have to say about it?  Thanks   Im pretty interested. Once im sure, we will have to figure how to do the deed.  ;]
Magscores
Mavendex
Quote from: Magluvin on August 31, 2011, 06:24:33 PM
Hey Mav
Magscores
Mags
Good to know about the chemistry, I wish we could buy wire that has a Permalloy coating but insulated from the wire. That would be rather interesting. good luck with your concoction, I wouldn't expect nothing to happen :D
I may be off on the gallons part but the nanopowder is <10nm particles so ya its the real deal, noncombustable with the water based stuff.
almost forgot, http://www.vivenano.com
Mav
Magluvin
Hey mav
Ya, I forgot you posted the pdf earlier, couple pages ago. ;]
Says  superparamagnetic    It seems a bit confusing, I hope it can be had just powder, no water.   Says it has a shelf life and needs refrigerated. :o   Sooo is it the water that causes the shelf life, or if powder/epoxy would preserve it?  ;]
I will send an e to them and ask a few questions.
And I uploaded the hazard sheet here
Mags
Hope
Nano magnetite is NOT the same mix as what you can get from the other link I researched for you all.
http://www.ruf.rice.edu/~natelson/theses/fursina_thesis.pdf  this link is ONLY to show you figure 1.4  it has a structure Water Russell drew once as matters creation.
Magnetite is like the stuff kids magic magnetic rocks are made of (bet you can't break one of these rocks).
This one IS nearly the same combo as the magnetec stuff.
http://xuzhounano.en.made-in-china.com/product/aqxQtgPbaScF/China-Nano-Magnetic-Cobalt-Powder-27NP-HW-.html
