High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
IronHead
Great to hear mramos
Be very careful  running OrthoHydrogen  in a piston engine alone.
Make sure this engine is something you can part with as this type of HHO will burn holes
in the pistons and heads if run with out a control gas or fuel.If you have a CO2 tank (Mig welder) sitting around you can put a little of CO2 in with the HHO and she will burn slower and not destroy your engine.
Good luck
IronHead
IronHead
key to make it run and not just fire on HHO is still burn time .
Run should not happen no matter the amount of gas .Your timing will not
let it run on this fast burn . It will pop pop a few time yes and maybe blow the head off with a lot of gas. You ether get the timing right or slow the burn and she will run if you have enough HHO.
Hydrogen engines you retard the timing  . I have seen from 7 to 80 degrees
Tuning is key  ether tune the gas or tune the engine  does not matter.
Discover tuning
IronHead
IronHead
Great stuff  keep up the good work.
You could also put a bit of baking soda in the cell
that will produce some CO2 and CO . How ever you do it
you seem to understand it all well. So good luck my friend.
Grumpy
"shaped controlled magnetic fields"
and
"controlled fields" as in other than magnetic.
eventually, perhaps, we won't even need water...
        -Frank Edwards
rapttor
I was very happy to find upon digging out my SS stock last night that I lucked out when I picked it up, it has very little if almost no magnetic properties what so ever.
I decided to go with plate sizes of 3" sq. and the connector plates will be 3" X 4" tall,
I'll get 48 pieces from this one plate, started cutting them on the bandsaw last night, but think I'll finish them with the angle grinder, should go quicker & allow me better accuracy.
Here's some pics...
-raptor
"I wasn't purposely airing my dirty laundry in the pic... it just happened that way"
Successfully Perpetually Failing at everything I do...
