Relative Permittivity of Water
Started by Torana, October 14, 2010, 04:35:01 AM
Torana
International independent test evaluation report 1995
http://www.free-energy-info.co.uk/WFCreport.pdf
The guts of it...index
5. purpose of content. establish dielectric value of water as being 78.54?
7. ken macneill . cadake ind secrecy order
8. pat bailey/ toby grotz
14. patent signing doc
16. 8XA fig 7 -4
20. fig AA water d value 78.54 OHM
22. 8XA vic *1981 ***NO COMPONENT VALUES**
23. 8XA1 vic AA *1981
24. 9XD V reg *1981
25. 9XB vari pulse gen *1981
26. 10XA rotary pulse *1981
27 . demo cell -9 tube
29 . photos
40. patent processing * 1983
41. Bio lab.  Na, K testing
42. research assoc inc
45. rob queen , SS * 1982
48. plexiglass
50. chemist affidavit *1982
60. * GAS fig* only
63. H2O
64. C5H12  Pentane  ,NOT natural gas
66. dr T Nagypal
71. electrical induced explosions in water
75. graneau/millet/azevedo * 1986
81. Dublin rea oniell
98 . phanomenon of the FE in nature. huber
102. taco bell
113. griffin
117. stan 65 mph @ 25mpL
129. science explained. metallic/ionic/polar bonds
NO WHERE IS THERE AN INDEPENDENT TEST IN THIS FILE
Torana
**Eugene Mallove was right and no one listened. No available test results.
Shame he had his brains bashed out!
http://www.greatdreams.com/mallove.htm
Walter Rosenthal, top test engineer.....No available test results.
Check last few sentences of mag article....No available test results.
http://www.icubenetwork.com/files/watercar/non-commercial/stanley_meyer/Magazine%20Document%20%5bpage%201of2%5d.jpg
http://www.icubenetwork.com/files/watercar/non-commercial/stanley_meyer/Magazine%20Document%20%5bpage%202of2%5d.jpg
Torana
A great man once said.....
"Oh the 8XA uses a 60 hz sine wave.......and I dont like it.......blah blah blah.."
SO......Ive just taken a look at **open-source-energy** and Hello......it seems the town folk over there have found problems with the 8XA and the SCR isnt doing the MAGIC* *(its a THYRISTOR)**
RWGresearch...
http://www.open-source-energy.org/?page_id=11
IT appears theyve found what Ive been saying turns out to be TRUTH......yet Im the bad guy(?)
tricky bit is....if Im wrong ,theyre wrong....IF theyre right Im right.....OR theyre becomming Bad guys ?  ....Whoops
********Good question=  Is this the circuit Tony woodside is selling? ? ? ?******
.......TIME to look at the components....
***It is actually standard practice to READ data sheets BEFORE beginning any project, FIRST**
**AND ITS FREE**
Torana
International independent analysis of 8XA control circuit components and Blah Blah...2011
control circ contains 6 chips that need stuff all current to run, 5- 18vdc,dissipation on data sheets.
it should only need 4 x 1N 4007 ,1 x 100 nf, 200v 100uf E cap for smoothing.
***This is a control circ NOT a POWER CIRCUIT.***
the last component in the chain is an opto isolator, that contains an Led and a photo transistor @ 150 mW.**
why use 8A BR?....for an Led
why use 6660uf Ecaps? ...for an Led..
why use 25W 100 ohm wire wound gate R?
SCR needs 80mA at the gate....? ? ?
SCR.
http://www.datasheetarchive.com/C38M-datasheet.html
http://www.datasheetarchive.com/indexdl/Scans-005/Scans-00109818.pdf
HEX.
http://pdf1.alldatasheet.com/datasheet-pdf/view/82662/ETC/7404.html
Divider.
http://pdf1.alldatasheet.com/datasheet-pdf/view/82082/ETC/7490.html
Diode.
http://pdf1.alldatasheet.com/datasheet-pdf/view/249632/VISHAY/1N1188.html
OPTO.
http://pdf1.alldatasheet.com/datasheet-pdf/view/52728/FAIRCHILD/H11D1.html
555 = 40 yesr old chip
http://pdf1.alldatasheet.com/datasheet-pdf/view/161279/TI/NE555.html
http://pdf1.alldatasheet.com/datasheet-pdf/view/28905/TI/TLC555.html
http://en.wikipedia.org/wiki/555_timer
