DRJ600 350% CNF reactor
Started by Doctor No, January 09, 2011, 05:58:05 PM
Doctor No
Quote from: lancaIV on January 09, 2011, 07:54:46 PM
350% efficiency,
C.O.P. : 3,5  electricity to heat conversion =optimized heat pump level !
        for example NOTOCO (NL)
heat pump performance optimizer f.e.  www.eats.ltd.uk/heating_cooling.html  "result in a COP of about 5"
Ok. Lancia. Can You prove it with real dates? For a better condition, i give real dates for smallest machine of this series, with 11 kW power engine: electrical power consumption 14.5 kW, heat output 50 kW. To have assurance of this last figure, i state, this machines boils tank of 300L of water from cold (10 to 100 degs) under 40 minutes. Can You do the same with heat pump of same nominal power? When so, i think i will do not to wait very long for answer (any).:-)
Doctor No
Nearly a year from start of this topic, 4 months from my last question to Lanca IV, and nothing.
Astounding if even MScoffman is realy interested yet?
pix
:-) Cavitation pump "copy-paste".
What is so special about? Others invented this long before.
On the picture is  ordinary electric water boiler with that pump working in closed circuit.
You didn't even managed to unplug electrical cord from the heater :-D.
As comparison.
Simple, ground source heat pump have COP over 4.
Air source heat pumps with modern control and compressor drive do not fall below COP 2.5 even till -15 deg Celsius outside temperature.
......you and your "home nuclear reactor" :-D.
pix
Doctor No
Im really astounded, how You all loose time on such not a broken penny worth writings.
And whats more, this is not HCNF. This as model only, can 4.800 sqm to heat 4 times cheaper over gas. With up to 1-10 MW engines, big units, can small towns to heat.
I assure You all, You are on the best way to oversleep whole XXI Century. ::)
mscoffman
Too bad DR. Nowak and organization could not have
productized these before the Rossi reactor, which
works on the similar LENR principles. These can
only work towards steam temperatures from below
because of their water liquid cores. While Rossi's
is starting his product design at steam temperatures
and can work upward in the future based in his
reactor's semi-solid core, this is what is needed
for efficient cycle energy conversion to electricity,
for example. It's amazing how all of the sudden people
become interested in productizing CF based device
after Rossi shows a better way to do things.
:S:MarkSCoffman
