Joule Ringer!
Started by lasersaber, December 29, 2010, 02:19:43 PM
0 Members and 23 Guests are viewing this topic.
woopy
Wow !! Lasersaber
well done
i will have a go on this one
I looked on ebay but the only RED big and thin toroids i have found are not METGLAS.
Are you sure that the red toroid is Metglas and have you eventually a number or something helpfull in order to find this part ?
Do you think that a big ferrite torroid could work , or no chance.?
Thank's for sharing
Laurent
T-1000
Quote from: wings on October 28, 2011, 02:33:26 AM
like in this video?
http://www.youtube.com/watch?v=fIFJ5o1eqsE&feature=mfu_in_order&list=UL
There are many ways for accomplishment on same result :)
I would prefer AV diode plug charging capacitor (remember LEDs lighted up in exciter?) then discharge to coil over Schmitt diodes or similar components (for general idea please see http://en.wikipedia.org/wiki/Schmitt_trigger ). The secondary coil could have connected to exciter so you would have coil-capacitor there for the link to first exciter. Also there are interesting power amplification result after scalar magnetic impulse forming so you get secondary exciter there :)
In my team lab this is done with high voltages and stuff but should be possible also with lower energy levels.
Have fun and good new experience! :)
I wrote down the circuit diagramm for this circuit and
it must be noted, that it is a Joule Thief circuit.
The primary 2 x 10 Windings coils wound in parallel
must NOT be connected to the transistor case at the top where in the pictured
the +13 Volts is stated !
The +13 Volts is only just connected to the 2 coils,
but not to the transistor case !
Very important !
Otherwise you would produce a shortcircuit of the battery !
The 750 Winding coil is just the 3rd coil as a pickup coil
which outputs the High Voltage AC.
As it is only about  2 to 4 Khz range ( estimated from
the annoying tone)
this AC voltage could be quite lethal, so avoid to touch and get shocked
by it !
Hope this helps.
Regards, Stefan.
xee2
This is what the circuit seems to be.
zhak
Quote from: lasersaber on October 27, 2011, 09:35:02 PM
Video: http://youtu.be/a0ni3noZMQ4
Check here for more info:  http://www.laserhacker.com/index.html
Dip the ferrite ring in the epoxy, it will not be so loud beep to make sounds
