The Bucking Magnet Motor
Started by z.monkey, August 25, 2010, 08:52:33 PM
Reisender
Yes absolutely! That is how it has to be done. If Perendev has told.
SEARL Engine runs in such a way. (Smoke have confirmed it.)
The engine PM3 is begun thus.
http://pes wiki.com/index.php/Directory:Magnetic_Motors:PM3
Gives an interesting history in addition from an amateur handicraftsman, name Harry. He has inserted a brake in the form of an openable door with his engine. After acceleration on rmp 1300 the engine accelerated and went immediately on rmp 50000. This Harry could not react. Everything broken.
Sorry for bad Englsich. It is an automatic translation.
z.monkey
Back in the Metal Shop on 11/11/11.
Taking all that funky numeric synchronicity and
channeling it into metal working...
So at 11:11 AM on 11/11/11 I was shredding metal...
\m/___(O.o)___\m/
Goodwill to All, for All is One!
z.monkey
Finally got some time to work on the UABMM this weekend.  Full elucidation here...
http://scientilosopher.blogspot.com/2012/05/uabmm2-test-fit.html
Been a little too busy with springtime, and the new business and all...
http://black-dog-technologies.blogspot.com/
Check out teh pix...
z.monkey
Now I have the bearings installed.  Full elucidation here.
http://scientilosopher.blogspot.com/2012/05/uabmm2-bearings.html
I needed to bore out the center holes of the bearing mounting brackets.  They were 0.500 inches, and the bearings are 1.125 inches outside diameter.  So I used a large Step-Drill, or Uni-Bit to do this.  These are off the shelf bearings from an Ace Hardware store, only $2 each.  So far I am pleased with them, even though they have more play than I would like.  I can always upgrade to better bearings later.
So now its spinning.  Next I need to assemble the Rotor Assembly...
z.monkey
I worked on the Rotor Assembly today...
http://scientilosopher.blogspot.com/2012/05/uabmm2-shaft-assembly.html
Video of the Rotating Assembly...
http://www.youtube.com/watch?v=svhaNLP8Zks
Nutshelled,
I made a shaft key,
made U blocks to hold the shaft,
machined a flat on the shaft,
press fit the split taper bushing,
drilled mounting holes in the Rotor,
assembled the rotor assembly,
then reassembled everything...
