Ibpointless2 Crystal Cells
triffid
There is always a certain amount of water in the air.And there is water locked away in the crystal structure itself.We may want that?If I am correct IB2 that you used no glue in your video of making another blue rod using copper pipe and magnesium strip.Only water,salt substitute and epson salts.If that was your video I will check later to see if it was.I have not been able to sleep tonight .I keep seeing ways to build these cells in my head.In my kitchen I have empty food cans that I wash and save since there are scrap companies paying nine cents a lb for them here in st.Louis,mo.I have three of them inside one another.One end removed.If I work hard enough I might get six inside one another in if I toss in a gallon can somewhere?So instead of copper pipes I use tin cans that usually get tossed anyway.Wrap your paper trick around them wet them down.Use heavy duty aluminum foil around them as the other metal electrode.Slip one inside another if I can.Years ago I read in a boy scout book how to make a homemade capacitor.You use two sheets of aluminum foil with wax paper in between.It could be scaled up to room size if I wanted.If both electrodes are the same metal you do get some power. However,I would make sure those two metals did not come out of the same melting pot!I would use one side heavy duty the other side thin.I want them to be as dissimilar as I can make them!
Anyway I must try to get some sleep.So see you later.Triffid
triffid
For that roomsized device I would not use wax paper.Some other kind of paper.Free If I can get it.triffid
triffid
Ib2,I have gone over the first four pages of this thread and cannot relocate your video that I saw earlier.Where you show us how to make a six inch blue cell?You used black electrical tape to hold down the paper,then using your hands you wet the paper.I worked in manufacturing for over 20 years and it seems that some of the processes here could be automated in a factory?At least at home for a guy who wants to power his home off of these devices.He might need a couple hundred batteries to get some major lights.triffid
ibpointless2
Videos on how to may my crystal cells
http://www.youtube.com/watch?v=t9U6GH9vgOI
http://www.youtube.com/watch?v=voBy5Km1mAg
http://www.youtube.com/watch?v=8EWATxAJooE
http://www.youtube.com/watch?v=2ngFfU1hHyM
Just because water is in the crystal lattice does not mean that the electrodes are going to touch the water, if that was true than just sticking electrodes in Epsom salt would give you a voltage. I have had many debates on the topic of water in the crystal with people and to prove that the cell does not use water from the Epsom salt just make a cell that has only Elmer's glue and Epsom salt and leave the salt substitute out, The is cell after a week will start to go dead unlike the crystal cells that contain elmer's glue, epsom salt, and salt substitute which will continue to give you voltage for a long time. If a cell needs constant water to keep the voltage alive than its galvanic, just like Bedini's alum crystal cell. If you want some reading about the crystal cells than I suggest you read the post here [size=78%]http://www.energeticforum.com/renewable-energy/7351-bedini-earth-light.html[/size] Its a lot of reading but it will get you caught up and see all the crystal cells that have been made.
triffid
Hi Ib2,the very first video in your last post was the video I had searched for and could not find.Thank you very much for posting it again for me.The second one with the tin can was one I had not seen.The last two I had seen before.Once again thank you for posting those for me.I think that since these crystal cells respond to pressure?.I think it is air pressure maintaining a voltage on these cells.We are the bottom of an air well with 14.7 lbs per square inch over our heads(sea level anyway).You have the uneven heating of the earth by the sun(night and day) Plus the earth is always rotating at about 1000 miles an hour on its axis.So air/weather is always moving around.So it might be we/you are tapping into those energies using your glue cells.Which is fantastic anyway!!To think you might have something that taps into the earths rotation is exciting too!Thank you very much.I don't think the water question is too important.Main thing keep water away from the cells.I get that!Thanks once again.Triffid
