Ibpointless2 Crystal Cells
0 Members and 1644 Guests are viewing this topic.
triffid
I don't know why NickZ says our cells don't work.Did he expect a 500 kilowatt cell?I know I thought I had 10 kilowatts a week until you guys told me I only had milliwatts.I thought at that time to stop but these crystal cells had me at .14 volts.One of the first crystal cells I had made with morton salt sub is still generating 1.02 volts.You really cant use too many dangerous chemicals at home.Some people have kids and pets,others tend to lick their fingers and poison themselves that way.You get too many chemicals at home and you have to start worrying about government rules.6th grade science experiments at home is ok.Better to be safe.triffid
ibpointless2
Quote from: triffid on March 09, 2012, 01:26:22 AM
On the other forum they called my cells nothing more than a  potato clock or a 5 grade experiment. They said my cell powering my LCD clock is nothing more than a potato clock, but the fact is that a potato powered clock only last for a week and my cells is still powering the clock for months now without a drop of water. I have done something that the others haven't done, and that was to keep voltage alive without the use of water. They say the things i use are childish things but what they don't realize is that our houses are full of chemicals of all kinds that are plum for picking. They see elmer's glue, I see a complex polymer of plastic that has a strong bond. They see dish detergent, I see a complex form of chemicals such as sodium hydrate, potassium hydrate, calcium carbonate, etc. We can't let the others get to us, I'm here to innovate so if it requires us to use milk than so be it, nothing ventured is nothing gained. Keep up the good work guys!  :)
jbignes5
 One simple question guys?
Is there a difference between 1 amp at 12 volts and 12 amps at 1 volt?
They say high voltage has no merit well to tell you the truth it merits tons of observations. Every knows that energy always follows the path of least resistance. High voltage has very low currents but it should be the same as low voltage at high currents. The trick is learning to convert and use the energy at the same time. High voltage generators would involve very little resistances and very little back force if the coils are properly designed.
What we do with 2k volts and .2 amps is the trick. We can convert it down and get more then we would need to drive traditional loads. And since the source doesn't reflect back to the source it redirects that reflection back into the stream.
I really like the contributions of nickz. He challenges our thinking and that drives us to find the answers. Just because Bedini has convinced him of his ideas of the process doesn't make it the truth of the experiment. Our experiments have swirved off tracks and now two opposing experiments are clashing heads. No problem. Just don't confuse the two experiments. One consumes a fuel(water) and the other utilizes the water for making discreet connections that are multiplicative.
triffid
I have no problem with people working in different directions and for different reasons.It sounded like NickZ was a researcher like the rest of us.He did make contributions That I paid attention to and respected.Other times he sounded like an energy company plant to tell us we are doing is no good and will never amount to a hill of beans.I did not like the two face attitude.I wish him well no matter his motivations.triffid
triffid
The buttermilk/vitamin C cells did not turn out as strong as I wanted them to be.I used buttermilk in the hope that what made it sour would give me a small boost in power plus milk itself is considered a glue by some people.I still want to use(up to five drops in each cell) vineagar in my cells.But I have to protect the magnesium metal somehow.Maybe I can use copper oxide coated copper wires to protect the copper electrodes.Fortunately I found a video that showed me how to coat my copper wires.Just heat them up on the hot plate plate until they turn red.When they turn black with the second type of copper oxide.That may work too?But red oxide is my target for now.Butter milk plus up to five drops of vineagar may work.triffid
