matthewklinko
Cheap4All
Hello Mav
I'm starting to get worried since its been a strangely long time since we last heard from you, in fact over 2 months now since you last checked in.
I hope all is well with you and that nothing untoward has happened, you haven't befallen any accidents, or anything like that.
Just getting concerning since you have gone so quiet for so long.
Just log in and tell us that you are Ok if nothing else...
Cheers
Mavendex
Sorry for the disappearing that hacker thing got real stupid took over my pc, churchs network, phone couldn't get on the internet. Church didn't want to pay me overtime for the work I was doing keeping thier stuff safe so I quit last week going to get my CEH and hunt those bastards down for making my life miserable, http://www.youtube.com/watch?v=NQbOG7STI7A&feature=channel here is a quick video of small gain on the device. Ill do another one when I finish this guy up.
Mav
Magluvin
Nice work Mav.  ;]
If your just using 60hz, those meters should be correct.  Good Good Good.
Thanks for enduring so long on this. It just goes to show that large amounts of time and persistence CAN pay off in this business.
Some out there would not agree.
Mags
Mavendex
Quote from: Magluvin on April 10, 2012, 08:24:54 PM
Nice work Mav.  ;]
Mags
Thanks Mags,
After that test I put a ballast in front of the transformer and the frequency dropped to 10 hz or so, but when I took readings at the ballast with my fluke the ballast was outputing 830 volts into the device at .15 amps @ 10hz probably what the ballast is set for, output of the device was 10hz 122volts 2.5 amps a nice almost 300 percent.
111 turns for secondary about 700 turns of primary, and the innercore was just holding the risidual power deffinitly more out than in @ 10hz when I input @ 60hz you could hear the hum of the magnetstrcition causeing problems in the shell which only made it about 105% effecient, so Im increaseing my secondary to 222 turns essentially doubling the output of the device, with 700 turns of primary.
Anomolies = 1 volt probe to 1 lead, 1 volt probe to ground in a potted plant = voltage reading on the fluke... about 280 volts out of the air, I think this is a function of the ballast or resonance or both. Ghost voltage was explained and they told me that if I grounded the other probe we would have a 0 reading on the lead, so since I actually grounded it theres still voltage we have a nice little unexplained deal going on.
Anomolies = 2 volt probes in the air = 10 volts reading on the fluke when the device is on, about 2 ft from the device. So she is creating a RF at 10hz won't work unless the balast is in place.
We are sending the device to have the secondary and primary profesionally wound.
Changes to the device was JBKwik on the outside to magnetically connect the shells, and then we put some copper foil around the outside gap and inside gap, this helped leverage the field, (the copper foil is sitting on the JB kwick and inner concotion of water weld and JBKwik on the inside gap still not connecting the shells)
input @ 10 hz I know is low but free energy is still that free energy, drop it into some caps and should be honky dory, increasing the windings on the secondary will give us more out and stacking cores, thinner shell, plus I found silicon steel innercores we can use price 60 bucks for the same size of toroid, vs 270 bucks out of germany, they will have a output of 2.0 teslas at saturation with the ability to move towards 2.5 teslas saturated like crazy.
Vs. the nanoperms which saturate at 1.2 teslas and are very expensive. all in all we can probably build these guys with the same design for less than 500 dollars,
Mav.
