Testing the TK Tar Baby
Magluvin
Hey Tk
Thanks for the vid.  Its interesting that the phase change happens. I had an inkling that it would. The reason being, I could not come up with any other change that might be happening between normal and SN modes.
So lets say if you have your Rx caps/light bulb on top of the coil, instead of the same a the Tx, where the caps are at the bottom, did you make up for that difference when hooking up the probe and gnd to the Rx?
Like if we were looking through the loops from one end, if your probe gnd is on the left(bottom) at the Tx coil, did you have the probe gnd on the right(top) of the Rx, being that the orientation of where the probe connections are, are different?
Just checking. Maybe it is out of phase in normal mode, and in phase in SNM.
Dont know if Im describing what I mean well enough.  ;]
Thanks for doing the vid. It is what I was wanting to see.  ;]  Perfect demo.
The "maybe" it will go into SNM issue must be something in the Tx and/or Rx, like the caps possibly changing temp once in SNM and when it falls out, at peak current just before drop out, the temperature coefficient could be changing the cap value till cool down.  Also, if the caps in the Tx have opposite TC, it could affect each oppositely. So it may be possible if using the same brand, value and type of caps in the Tx and Rx, when they heat up, they would scale their values in the same directions when heating up and maybe avoiding dropouts as early and a more consistent lockup when going for SNM.  ;]
MaGs
Magluvin
Quote from: evolvingape on July 18, 2012, 03:46:07 PM
I also like the Zen aspect, I myself in my younger days studied Bruce Lee's book, Tao of Jeet Kune Do, it became my mental and physical bible and allowed me to progress to a point where the one thumb press up was no longer a dream. Be like water, my friend.
I had all his books when I was younger. I started boxing at 14 and used most all of his ideas for workout and what ever was legal in boxing. Bruce Lee Fighting Method series.
My trainers used to call me the cat. They always tried to take credit for my "fighting method", but I let them have their glory on that note. ;]
MaGs
evolvingape
Hi TK,
Well done, you understood perfectly. The video you linked perfectly demonstrates the principles and structure involved (and almost the exact apparatus I am playing with), however, there should be two close tolerance tubes... one fixed and the other a linear oscillator. The ring is fixed to one tube, the cylinder fixed to the other. The magnets move in respect to each other, but fixed in relation to their respective tubes. So you glue each magnet to it's tube, is what I am trying to say and it is the tubes that move to transmit force and actuate, suitably greased to minimise friction of course.
Think about the finger that  pushes the cylinder magnet, it is storing force in the magnetic fields of both magnets in repulsion mode, until the distance = 0 and then the cylinder pops through the inside of the ring magnet and the vector sign flips. At this point you are going from maximum stored static potential to maximum dynamic acceleration as the magnets repel each other with a force exactly equal to what was stored.
The previous post covered the exploitation of potential difference between Hooke's Law and magnetism, both operating on the same axis... however I have since moved way beyond this basic principle. Look at this:
http://www.spudfiles.com/forums/i-gotz-a-35-bar-pushbutton-valve-t18317.html
Here they are discussing the balanced piston valve and one of the original designs from 2009. The key thing about this valve is that it is balanced, with equal gas pressure on both sides, the bias being provided by the compression spring which is weak enough to be pushed with a finger, or a less energy intensive voice coil linear actuator. ;) (No magnets in this design by the way, just a simple spring and balanced gas pressure).
However, I have been able to remove the compression spring completely, and Hooke's Law in the process, using gas pressure alone by filling from pilot side (use the search function!), and shifted the balance point from central to the extreme, storing that energy in the magnetic fields. So effectively, the same actuation force is required to actuate but you have almost the full power acting in a negative vector when it "pops", in addition to the positive pressure acting in the same direction = ?
I will cover it more fully in the actual post which will probably be over the weekend. In the meantime, if you have a moment to ponder, just think about moving the zero point to maximum offset... oh the irony...
Time for bed, night all.
P.S. Mags... Legal ? If it's got rules it's a sport...
P.P.S. Guns and engines work on the same principle, Repulsion of Mass from rapidly expanding mediums. People who study only one, or the other, understand neither.
https://www.youtube.com/watch?v=oau7xU4H8RY&list=UUSvNzUDvn7FA8YBJM9E6o1A&index=2&feature=plcp
Magluvin
Quote from: evolvingape on July 18, 2012, 08:11:23 PM
Well, in boxing, you cant stop a jab with one hand, and follow with a back fist to the face. Also no kicking. Legal in boxing, is what I meant.
MaGs
An electric koan: What is the brilliance of three bulbs shining?
The monastery is quiet; all the monks are studying and copying ancient manuscripts from an almost forgotten past. Tada Ima, a novice from the South, opens a crumbling text and out falls a strange diagram. He immediately takes it to his master, Jen Shin, who happens to have a PhD in electrical engineering, which he obtained before he attained Zen and opened his monastery. Master Jen looks at Tada's diagram, snatches it away and blows his nose on it, crumples it up and tosses it into the brazier. "Thank you, I needed a hanky".
Fortunately Tada Ima has a photographic memory and a lot of time on his hands.
Three identical 12-volt incandescent filament bulbs are wired into a simple circuit as shown. What does the voltmeter read? Are any of the bulbs lit, and if so, how brightly?
