Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
starcruiser
Quote from: Zeitmaschine on July 22, 2012, 07:33:01 AM
Let's calculate: 5000W at 220V = 23A, 5000W at 12V = 416A
Hence a hidden 12V battery in the green box had to provide 416 amps of current for at least 1 - 2 minutes without being heavy, because any heavy weight (like a car battery) in the green box would have been extremely suspicious (at least to whooshman).
Any idea what kind of battery this could be? ???
Lithium polymer (LiPo) type, used in RC models, the lithium Ion (liOn) or Lithium Iron (LiFe) can source this type of current for short durations. I have several packs (LiPo) that can source 24v @ 178amps for several minutes prior to being depleted there are others that can exceed this and output up to 330amps if desired.
Thee nice thing about these packs is they are small in comparison to Pb (lead acid) types.
Check this site out, this shows the batteries I mentioned above  http://www.readyheli.com/TH500045C6S-Thor-5000mah-6S-222V-45C-Lipo-Pack_p_40325.html
24v dc @ 5000mAh with a discharge capability of 45 times the rated, i.e. 5000 x 45 = 225amps, run a couple of these in parallel and you can source that current easily. These have a pretty flat discharge curve too.
Pack Dimensions: 152.4 x 44.45 x 50.8 mm
Carl
Zeitmaschine
Quote from: starcruiser on July 22, 2012, 11:38:32 AM
Then the next task (in the green box) would be to convert 208A 24V DC to 23A 220V AC. TK's light blue (big) inverter is rated 400W, so in the green box there has to be another inverter, capable of doing 5000W output. ::)
Quote from: cheappower2012 on July 20, 2012, 06:54:58 PM
The heating of the transistors is fake,in my opinion the transistors do nothing its to fake you out.
Watch this very closely:
Kapanadze 28th April 2004 full version free energy device
17.02 Kapanadze switches on the inverter, humming noise, but no spark
17.15 Kapanadze connects the inverter to AC outlet, humming noise ceases
17.17 spark appears with two seconds delay
17.25 Kapanadze removes the AC outlet (auxiliary) connection (audible)
17.36 second man switches on the lamps
20.14 again Kapanadze switches on the inverter, no spark
20.20 again Kapanadze connects the inverter to AC outlet (shakes the plug)
20.35 camera zooms in on the spark gap, no spark visible (all waiting for spark)
20.44 camera zooms out, Kapanadze removes the AC outlet connection
20.45 still no spark visible
20.46 still no spark visible
20.47 still no spark visible
20.48 second man switches on the lamps
Why does Kapanadze pull the auxiliary plug at a time when there is clearly no spark visible (compared to 17:31)? Because the spark is not needed anyway?
Maybe I'm mistaken, but do we need the high voltage spark and the helical coil at all? Moreover, there is no reference to high voltage (and helical coil) in the patent specifications. If high voltage is mandatory, how can the patent ever be valid without mention it?
This device gets more and more strange every day. For one the transistors are fake, next one says coils and cables are fake, now spark seems to be fake. Anything left here that is not fake? ??? >:(
sparks
These chemical power packs are dwarfed by dynamic energy storage systems.  Please investigate what exactly Tesla would fall asleep in.   A  Tesla wave is produced in all capacitors including a spark gap.  It is the instantaneous charging we see when a charged cloud passes over a portion of the Earth.  The Earth instantaneously is charged opposite that of the cloud.  The cloud is negatively charged due to the aggregation of hydroxide ions on the surface of water droplets.  The tiny antennae respond to infrared emradiation and heat the water droplets causing them to expand and rise higher into the atmosphere.  When these droplets begin to contract when the Sun goes down or they are shadowed by higher elevation clouds they condense into rain.  When they do this they form the tiny passive infrared antennae again on their air to surface interface.  Water is self-ionizing and requires no energy input to create these tiny antennae.  They are the perfect passive infrared detectors of nature.  Florida has the most surface water to air interface in the continental US.  Unlike other places on Earth it is void of the topological features that concentrate water into rivers. This allows for infrared capture and recycle to produce large amounts of charged clouds.   This results in large amounts of currents as the clouds exchange charge flux depending upon how many hydroxide ions they have on the water droplets surfaces in the mass of the clouds.  The water vapor "boiling" off the heated water surfaces rise rapidly into upper strata where they form a giant bubble of watervapor.  Cumulous clouds will develop barely a 1/2 mile up with perfectly flat bottoms that slide along the water vapor bubble.  The water vapor bubble surface is then convectively cooled by the cloud and converted in water droplets which are then randomly distributed in the cloud depending on all sorts of factors like updraft currents and atmospheric compression shadowing angle of solar radiation etc.  As the upper atmosphere cools it compresses the clouds and this compression is released in electrical and  rain events until the clouds redistribute the energy flux difference.
  If you create a system that converts infrared radiation into lower frequency oscillations you will have created exactly what a very creative man did quite awhile ago and ancient civilizations did quite awhile ago using pyraelectric transducers  coatng large pyra-mid structures.  The Pyra-mid structures would transduce or reside midway between infrared radiation and electrical energy storage and reconfiguration devices.  The pyramids we see now are poorly crafted replications of technology once employed by advanced humans.  There are various relics distributed in the pyramids that are directly from this advanced technological society.  This is why there is so much trouble dating the pyramids because parts of it were transported from the original sites by the nitwit pharohs.  This is why you will find granite blocks which were lazer cut sitting next to limestone blocks that were gauged out by pharohs slaves.  The idiots in attempting to replicate the really ancient structures coated the pyramid with gypsum and deforrested the nile river valley doing it.  Dark age products for sure.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
forest
Again video from 2004 year and again not translated  :'( to English
cheappower2012
@Zeitmaschine,good answer to starcruiser
,in addition you have to take in account that
the year of the video is 2004,
not 2012,what batteries could you get in 2004 in Georgia.If the TK device were fake a turkey company
would never build and  test a big unit.The transistors are debatable,I see only two wires,the
video is too poor to resolve this issue
accurately.On the transformer and rectifiers in 2004 video,the rectifiers are high current,
then why is the current conducted by very thin
wires to the can,the presence of the suit from turkey in the 2004 video,meant he had
to fake out the suit.
In my opinion the spark
is necessary to disrupt space,the coil creates a temporary disruption of space,induction
as in a Tesla coil is not the purpose of the spark.
Because the extreme amount of current that the TK device puts out,you need a source of
energy,you need to convert that energy to electrical energy
in a way it is not a free energy device since no device can defeat,conservation of energy
and matter.As why is there no spark in parts you wrote about in your post,the video is poor quality,
,the suit is close by and is looking for a spark,if he doesn't see a spark ,he may say fake,so there has to be a spark,we don't know what TK said,
when he told whooshman to turn it on.
Also in the transparent video,the spark duration is very slow so the device doesn't need a continuous spark,there could have been spurts
when the spark jumped ,not visible in the video and TK said turn it on knowing that after its on it would continue to run.The real problem is theres
no translation as to whats said.The patients will not help you to build it,TK is a tricky guy,exactly how to build the device
is not in the patient,that's by design.
