Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
Pirate88179
The aquarium video is great!  Thank you for posting it.
Bill
forest
Quote from: dole on August 08, 2012, 08:15:19 PM
black box: it must be capacitors and if it should be simple he is charging them and discharging through load back to source in closed loop gaining charge as shown in his patent.  TK reference to Tesla: Tesla believed that capacitors is source of unlimited energy, he did not believe, he knew. So it myth remain only one simple question, how exactly TK "switching" them.
d.
Exactly, hard to get it working with electronic switch. Was there any noise from rotary interrupter in box ? Even if so it was probably covered by spark gap noise.
forest
Quote from: 27Bubba on August 08, 2012, 10:19:36 PM
"2012 Aquarium2 video now available."
Really enjoyed the video. Thanks for sharing.
So, this is different setup that the green box and the burred radiator video.. It only use one ground wire. So there is principal difference in the design, operation and output? There must be something buried inside that both of those designs share that make them work.
C'mon 27Bubba -  why you think there are two ground connections ? Did you watched green box video carefully ? There is also a video somewhere with english subtitles. I can't find second ground there  - just in first part a car radiator was buried in soil with cable attached, then device was gronded to water faucet. Later the test was performed to see if another ground (radiator) can work, device was connected now only to this second ground.Tariel was concerned about the total load so it was started with one bulb then 2 then 3 and output was not such big as with faucet and clearly Tariel wanted to cut power as fast as possible probably worrying about damage to the device.
Can we finally agree to ONLY ONE GROUND connection so nobody would return to this topic and mess around ?
balphom
I do agree that digital meters cant be reliable in measuring where there is high frequency, but the readings do much the load, how
We have been relying on what we see in tk devises so much that we cant think outside what we do not see and tk knows this, he will give you everything you want to see just to mislead you.
The device can not work without earth connection, i said before and i will say it again and again and again.
Tk is using counter power from the earth to power his load, you only need to think how.
captainkt
Hi@ How was 2012 Tk Aquariam gen started and stopped?
Keith
