Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
wattsup
@jbignes5
In the 2004 video (notice how right away I am identifying what I am talking about in this post) we have to simply consider that the plug that goes behind the inverter and that is plugged into the mains socket (back plug), well, that wire is just entering the back but is going directly to the inverter output plug. This is because his battery voltage is going down and down and he does not have enough juice in the battery to start up the system with the inverter and he uses the back plug as a boost start. So there is nothing special there to consider.
Unfortunately, it is clear now that the devices do not require a spark gap. This was made crystal clear in the Aq2 build where the spark gap wires head directly into the hidden areas of the build, before the output of the triple transformer, so there is no relation between the spark and the output. This explains why the spark cadence was low frequency 10Hz. If they used a smaller spark discharge capacitor, that spark frequency would have been faster. Why did it take so long to get to this point??????????????
The devices work using mains supply regardless of the source method. This mains supply is shorted to the rectified output of the transformer secondary via the two switching heat sinks and the capacitor and is creating some rather havoc stricken effects that will even create flyback from the secondary back to the primary, working like an energy pump amplifier. The bulbs are just receiving the brunt havoc end of all this activity and as long as you are faster then 50Hz, you will not see the lights flickering so you have no way of knowing the actual working frequency.
@Jack Noskills was doing something similar with two transformers but it can be done with only one transformer, a rectifier, two switches and a capacitor via a passive switching method that has nothing to do with anything located inside the tin can. The tin can has enough space to only hold a HV device for the spark illusion and space for all the wiring connections. Any switching circuit would have to be robust and reliable enough to handle all the havoc so I don't think they had any complex switching system. Also, I am convinced the spark stopped in the 2004 video because the diode plate was shorting out on the 6 turn coil. hehehe
This all makes so much more sense now and can be tied in logically with all the TK devices.
I guess TK is only happy as long as guys are sparking away. So maybe during our next bench trials we should include a spark gap that has nothing to do with the experiments but only to keep TK happy thinking we are on the wrong track. After all, we aim to please. lolololololol
So back to the bench and trials with the TKc and a step down transformer via the mains.
I think I will need to find two 50 volt - 6 to 12 amp zenor diodes and a 120v to 60volt step down transformer. I should have something close to that already on hand.
ZENOR DIODES come in all sizes and shapes, from the regular small reds and blacks to the two pinned mosfet type and even in the sizes seen on the 2004 diode plate. So here is a side question.
Has anyone ever made a full wave bridge rectifier using zenor diodes? That may be a simple enough thing to hide in plain sight but what would be the effect? If the diode plate used zenor diodes, would that create a pulsing effect?
wattsup
yfree
Quote from: verpies on September 21, 2012, 01:34:59 PM
Maybe it did, but it destroyed itself in the process.
Wouldn't it be something if the destructive Ferroresonance had its origin in NMR all along?
This is probable, but to be able to utilize this, the construction of a transformer has to be different. In the 2004 video, the visible transformer is conventional. The device in quoted Fig. 1 is also a transformer.
jbignes5
So I'm guessing no one read the link I provided including the book from archive.org
The wave theory in that book handles all forms of waves including stationary waves. It explains what the power company engineers have know for many many years.
If you read it you would see that the spark gap is merely a way to get the very sharp oscillations needed to produce these waves. It also lets the voltage ramp up as well.
Please goto the lecture X in the book and read that secition page 132 of the djvu viewer. In that section it talks about what I suspect is the method TK is using.
It doesn't matter anyways if I must I will build the device myself and show you all.. Got to give me a few months to get things together.
Until then just keep assuming instead of doing.
Anyways here is a short clip of the coil and where he got the idea...
http://www.youtube.com/watch?v=PG3ALEVkILE&feature=related
Zeitmaschine
Quote from: wattsup on September 21, 2012, 01:35:51 PM
This would risk a short circuit and blowing the fuse because the device is grounded. Hence no direct connection to mains is allowed. :D
Quote from: jbignes5 on September 21, 2012, 02:26:39 PM
So the power company engineers have known for many years about Free Energy? ??? ???
Go ahead.
That's the point. Why is he showing the coil from close up in front of the camera? Why not the transformer? Any ideas? ::) 8)
Anyway, this is a nice setup: http://www.youtube.com/watch?v=3r8ZP4XOkYI
A bank of capacitors (looks familiar?) which boosts the power of ten microwave oven transformers significantly.
Quote from: yfree on September 21, 2012, 01:12:41 PM
For over 100 years, this type of a transformer has never produced any extra energy. Why should it produce energy this time?
Because this time the transformer runs in a closed loop hence there is a great chance the produced energy is even recognized as such?
jbignes5
 A: did you read the book or not?
B: The book is not about free energy it is about waves and how they can and will influence a biased wire. Just go to this link and go to the page I mentioned with the chapter Header: Lecture X
[size=78%]http://ia700402.us.archive.org//load_djvu_applet.php?file=4/items/ElectricDischargesWavesAndImpulses/ElectricDischargesWavesAndImpulses.djvu[/size]
The whole book is a treatise on what the power companies learned over the years about switching the gens on and off from the power lines. What effects shorts to ground have on the lines and the transformers on each end. The resulting waves of both damped and undamped waves are talked about in the book. I would suggest reading the whole book but I guess no one wants to educate themselves. Instead you would rather sit and postulate about subjects you have no clue about.
You know how I know you have no clue about them? Because it says no one has really delved into the transients and what effects they have. We know little about this stuff because the transients were always shunted to ground. Which is the only high capacity they could shunt into. Read and learn what the professionals who works on those systems learned by trial and error.
The system that TK devised is on par with a Tesla system.
The reference that I made to the short clip was about the NEWSPAPER he was holding. Not the coil. Ever heard of the Tesla Death Ray? It could be very well that the can is empty and is only the target of this Ray gun. It is after all on the one end of the coil. Who knows at this point.
