Joule Ringer!
Started by lasersaber, December 29, 2010, 02:19:43 PM
0 Members and 30 Guests are viewing this topic.
stprue
Quote from: gyulasun on September 29, 2012, 04:52:07 PM
Hi sprue,
Please read this post I wrote to Skywatcher, maybe it can help you.
http://www.energeticforum.com/renewable-energy/7051-joule-ringer-51.html#post210112
I am not sure: you use a neon bulb as the light bulb?  then just use a parallel variable resistor to give start current to the base of the transistor.
Gyula
Hello,
I will try this, but Lasersaber did not need a base resistance for his crt to auto start.
jbignes5
I heard someone talking about looping back to the source. If you do this make sure you do it via a good isolation transformer and diode bridge with cap. This should work extremely well.
gadgetmall
Hi The basic concept of the delay line is post 550 . I would two of those e cores . But different  . I used #36 wire inside about 5000 turns and centertapped another layer about 1000 turns and put the paper foil paper and then wrapped my plastic coated bell wire the length . with 1 .2 volts feeding the 1000 turns and outside bell wire as a normal jy hook up i get about 900 volts from the inside 5000 secondary . it light led bulbs nicely and will dimly light a cfl bulb . not happy . I know i can throw  5 volts to it and go bright on the cfl .. its been running for 24 hours buzzing and lighting that  cfl  nightlight style with an 1500 farad ultracap . it started at 2.687 and is 2.508 after 24 hours . I want to kill it and see how many days it will go . In the meantime i bought one of those EXPENSIVE Ferrite rods . That thing was 29 dollars for that fat rod. I thought he said they were 2 dollars . WRONG. anyways i will have his exact stuff . i want to see a 60watt filament burn off one battery like he showed . If it does im shooting it 12 volts and sticking in a power strip . :)
JouleSeeker
    I've replicated Lasersaber's 3.0, based on an operating 2.0 version that I had previously.  Then, I simply took the output wire that was connected to the emitter on the 2N3055 (2.0 version) and moved it to the collector.  It worked great!
    I then ran with 6 LED bulbs in my light-box, as I had done with the 2.0.  I found that the light output was about the same for the two versions (109 Lm/W for the 3.0 versus 112 Lm/W for the older 2.0 -- at 12.8V input).
    Next, I hooked up the output to my "Davey-bell" system and observed a LOT of electrolysis;  but no xs heat.  (I've pointed out elsewhere how I see many similarities between so-called "cold-fusion" experiments which I've done for many years and the Davey invention patented in 1944 by Peter Davey.  Both have electrodes and electrolysis; both claim "excess (xs) heat" under certain circumstances.  )
I made a quick vid of this effort today:
http://www.youtube.com/watch?v=0DtvKnZk9iM&feature=youtu.be
gadgetmall
Jouleseeker are you saying you could not get the same results with version three with the ferrite rod? If not why?
@conradelektro
The Schematic you got off Ls site looks wrong to me . On his ferrite rod i know there are more than twenty turns on that , there has got to be at least 400  to 600 turns on his inside coil and for sure more than 200 on the outside looking at the video and the length of these things . what do think? he said #30 . that is fine wire . also that roll of insulated wire is big and given the size twenty turns would not go an inch on that rod. I will try it buy i don't want to spend a year and half on it like i did the jr1 .
