Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
rensseak
Quote from: devilzangel on June 07, 2007, 06:40:51 AM
@Gustav22 .. thanks for the translation .. appreciated
@OTTO - please let us know why u r saying it is an aluminum alloy sink.
@norbert - answering question with questions isNT going to take u out of that chaos. even if the suggestion is wrong, atleast it was put out on the table in the forum for everybody to know that it was wrong .. so others will also think about it  ;D
devilzangel
oh sorry, it was not a question just a suggestion and i dont even ask for answering.
regards Norbert
Bruce_TPU
@ Rich
Some more great information about exactly what oscillators to use, to add to the .pdf
Also that the Collectors are "two conductors" each as Otto posted on my thread, unless everyone but me had already figured that out! LOL
@ Otto
SM said to start the frequencies up, ONE AT A Time.  First the resonant, then harmonic, and then intermodulation.  That would suggest to me that we do not want the frequencies "syncronized", would it not?
If you are wanting more power, I suggest making your next collectors and "tuning" them to one of SM's specific frequencies, by making sure the "resonant" frequency of your coil MATCHES the first frequency you are using.
Once I first replicate your work, that is my first task.   ;)
Blessings,
Bruce
Grumpy
Otto,
About the oscillators:
Can you provide minimum current and voltage requirements ?  (I know you stated 5v before.)
What are the specifications for your square waves?  What is the width?  You give a frequency and voltage level.  Are the square waves same width and space? (50%)  Have you tried other widths?
        -Frank Edwards
gn0stik
Guys,
about aluminum.
If you read erfinder's posts that inspired some of otto's work, you will note that it's not the superconductive properties, but the Paramagnetic properties of aluminum, that are important, just a note on context if you'll hear it.
I have not been able to start winding yet :(, very frustrating.
I don't think my oscillators will be sufficient. I have to crack one open and see if they use mosfets or transistors. Then i'll know for sure.
Also, I'm kinda short on time as you all know keeping a house clean for interested parties, is a bit of a pain in the neck.
My schedule in unpredictable, and my wife doesn't want me to have my spaghetti experiments all over the place if someone comes to see the house.
*spaghetti of science* I say under my breath.
anyway. we trudge on.
bob, grumpy, chris, gk speak your minds. don't be so thin skinned.
anyway, just a quick shout out to you guys before I head to work.
Rich
Earl
Bruce,
this implies to me that the resonant frequency = fundamental freq.
Between the fundamental and all its harmonics exist both frequency and phase synchronization.
Regards, Earl
Quote from: btentzer on June 07, 2007, 09:20:21 AM
@ Otto
