Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 323 Guests are viewing this topic.
Dom Tesla
Hey Guys...
How I believe it can work:
The input circuit is high impedance the output circuit is low impedence. The output part has a resonance of one quater to the signal pulsing through it. If the output circuit is also harmonically tuned to the earths resonance frequency, the occilations spontaneously start to grow.The key here is to render the impedance of the output coil near zero.... liquid nitrogen? Also you need a elevated capacitance as a virtual ground for the load.... cant just plug it into the ground.....
But how do we know his devices really work? we dont.... Tariel is just another Trawöger a egodriven wannabe-inventor.... wich does not mean that the device is impossible to build. It just seems to me that the device is just something else, than what he tells us....
I feel like its just a monopole, 1 wire electrical system, he probably has the generator running in the backyard....
Read Teslas patents..
Tell me what you guys think, thumbs up :)
captainkt
 @xenomorphlabs, in 2004 and green box kapanadze does not disconnect the inverter it is part of the circuit when he self runs, I pointed this out 500 posts ago.
Keith
captainkt
@wattsup, I do believe that bulbs are infact 1000 watts each a bit scary by normal standards, but on some of the Russian vids the camera shows close up of bulb tops with rating etched on.
Keith
xenomorphlabs
Quote from: captainkt on November 05, 2012, 06:33:31 AM
Keith
Admitted. You are right, the guy just disconnected the battery and not the inverter per se.
In that case the possibilities for the output are indeed more diverse and would just need to be transformed/rectified to 12 V DC. (If that is really how he looped it, contrary to what his patent states)
Still the behaviour of the clamp does not exhibit a clear sign of strong interference (jumping around), so the frequency in the load circuit
must be close to (or have a maximal component of) 50 Hz AC.
Сергей В.
Привет народ !!
Translated from France
Refuge de Sarenne - Sarenn's Shelter
00:35 - Here already more than 10 years ago, Sarenn' shelter was uselessly looking for the answer, which will answered on ours requirements for alternative sources of electricity. Till today I have paid attention to the different alternative  sources of the electric power, as on a photo cell, wind-generatorss, hydrogene etc. All of these sources had one main point. Their phenomenon were stopped quickly.  The sun wasn't shone whole day, the wind disappeared from time to time. And from the oil generator energy is expensive and also difficult to obtain.
01:07 — I then found in the Internet the generator Tariel Kapanadze. This generator give us the chance to get free electricity by means of earth grounding , to get from the earth charged particles. On the basis of rotation of the earth If you have understanding - a source of high charged particles is our sun, which unfortunately shine only up to 10 hours per day, but helpfully the earth rotates constantly and the earth's journey can't be stopped.
01:35 - Of course, what we doing? From the earth we could allocate energy in a condition of charged particles and to submit those particles to the initial or primary coil or as we called it - the Tesla coil. Then further we will charge a copper pipes.
01:45 - Copper pipes can't be from ordinary copper but oxygen free cooper or vacuum melted cooper with the purity of 99,99%. This is most important.
01:56 - On a pipe we put the ferrite rings with high magnetic permeability which should filter unwanted particles from the coil which will be charged by the means of resonance.
02:05 - We also have here initial source of 12 volts - the accumulator. For start even the small accum.batteries will be sufficient.
02:14 - Next high-voltage generator to generate high voltage potencial for the primary Caduceus coil.
02:22 - We have here two coils, the first modulation and the second output coil.
02:28 - The modulation coil make a resonance in Ether.
02:30 - Here is demonstration of all this. It is well audible in work, and we can hear radiation of charged particles which  pump up (excite) the primary coil. Here is also well visible how charged  particles were combined, similar like in Kapagen, with the help of coil resonance and we have got the effect.
03:02 - Joining occurs here, where voltage provide the charging. That charging here occur possibly because we consume some energy from  120 to 130 watt likely ?
03:04 - As already demonstrated, we can here shining  2 kW (bulbs). Maybe not full 2kW, but in whole it will be 2 kW.
03:22 - In this stage we can use this type of energy for heating the loads. I want to remain your attention here on this exciter, which with help of small battery, (two batteries) and from two coils can produce enough energy to boiling the water  how much is needed.
03:47 - All these principles were known for us, several years ago. What is necessary that everything we need to put in action to bring the power but for now that is not enough. To get a resonance in a present time it's easy. It is system of Kapanadze and it is very simple if we have oxygen free copper. And to get a charged particles isn't difficult. Apparently, only  in our hands world have a chace to rescue. We can answer in our electricity requirements, as on individuals, also on collective level, 20-30 man.  If i can get 2kW,  i can get with easy 4, 6, 7 kW for use. I think we could create the generator which would have 105kW.
We can make the conclusion now. What decision we will accept, it will depend from us and from collective awareness. It's necessary to make decision and to make a move, not to sit in opposition and make empty criticize. For the first move we need to take control of our future.  If we want abdication from nuclear power plants  then we should abdicate to be the consumers. It's absurd to criticize prostitution and every evening to get a new . There are people which love  only  to criticize nuclear power plants and every evening they turned on the switches and consumed their electricity. I have a huge privilege. I can answer on my electricity requirements. It mean that I freely may criticize. But it's not good to be an criticizer from one hand and from another to be a consumer.
Video:
http://www.youtube.com/watch?v=sNveUeEuV2o
ps. The author of Refuge de Sarenne OU Generator is not Fabrice Andrei. Author is very well known to many on this forum but don't  dig to much and don't dig deeply in your try to find the author. In the near future maybe the author will present himself freely. Now is time to as many people as can doing successful replications and to present their labour to whole mankind. As Andrei said The Future is in our hands !! Remember it !!
ps2. From one friend from Russian forum Realstrannik i have got information about his successful replication of small infinite OU flashing light. He said he used oxigen free copper. Also i have information that Donald Smith have used oxigen free copper wire and very probably Stiv Mark. So we have valuable information and that information need to be checked and verified !!
Сергей В.
