Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
MeggerMan
Hi Roberto,
I have to agree with you there, poor choice of mosfet driver:
ICL7667 made by Intersil, pdf document states 1999, so its about 8 years old. Around 200-300mA drive current.
http://www.farnell.com/datasheets/63698.pdf
This one is a bit quicker but not less than 10ns
http://focus.ti.com/lit/ds/symlink/ucc37324.pdf
Here we go: DEIC420
http://www.ixysrf.com/pdf/driver_ICs/DEIC420.pdf
Ultrafast, less than 4ns rise time into 2nF load with 20A max. current
Max freq. is 45MHz
BUT, and this is a big but, they cost a whopping 18GBP each, even I gulped at the price.
Burn out 3 of these and you would be slightly miffed.
Roberto, why such a sharp rise/fall time?
What driver are you using?
Rob
Bruce_TPU
Thank you Rob!
18 GBP to US is $35.38 each times three is about $106.00 towards a working TPU.  Not too bad.  (unless you fry them of course  ;D) LOL
We need to price them here in the US and Germany and see if we can find them any cheaper.  Or Roberto when he posts his circuit, I am sure will have some suggestions...
Cheers,
Bruce
Grumpy
        -Frank Edwards
chrisC
@tishatang
That was really a magnanimous gesture on your part in offering your scope to Otto so he can proceed on his TPU work of excellence! However, I think Otto is already waiting delivery of a new scope bought by 2 members of the Forum since he fried his last scope!
If Otto does not want it, I am pretty sure I can make use of it if you want to send it my way! I have been wanting to start replicating Otto's TPU since I now have a pretty good understanding of the 'principles' invloved. I'll be glad to pay the shipping anywhere in the U.S since I am located in san Jose, CA.
btw, 70 is not old! My father in law is 94 and is very much alive and kicking (however, not like TPU kicks!)
ChrisC
mkt3920
Quote from: tishatang on June 08, 2007, 06:21:52 PM
It has been really exciting being here searching for the elusive TPU.
Good luck to all!
Tishatang
Tishatang,
Thank you for your input in the past and good to see you posting again.  You have my respect and you had very good insights into "harmonics" and "mobius" last year.  Congratulations on the marriage.
http://www.overunity.com/index.php/topic,712.msg16416.html#msg16416
Kent
