Otto`s replication of Steven Mark`s TPU
Started by otto, April 17, 2007, 02:32:36 AM
ronotte
Hi all,
I DO UNDERSTAND THAT THERE ARE MANY CORRECT QUESTIONS
Please be only a little patience and you'll find all the very needed answers.
Be sure that together Otto we will provide for any possible detail/answer within our best knowledge.
We are working for all without any limitation. You all are kindly invited to join us in this event.
@Marco
You are absolutely correct.
starcruiser
SO let me see if I understand the construction then, so by using a 1" diameter silicone tube/hose, bent into a loop to achieve an outside diameter of 6" we would then have an automatic 4" inner diameter. Then by gluing the lampcord as marco has shown on the bent tube we have our collectors.
Roberto and otto say to wind the control coils separately then slide them on the collector assembly into the correct positions.
Seems easy enough.
another thought, now maybe I am getting ahead of myself here (something to try after replicating otto's work) would be to use 1/4' copper tubing for the collectors (of course we would need to cover them, perhaps with heat shrink tubing, to isolate the conductors/collectors).
patiently waiting for otto and roberto to finish their doc's and tests.
Carl
dutchy1966
To everyone who still cant imagine the setup:
There are two tubes (1 cm diameter):
a 6 inch diameter ring with a single loop lampwire glued on the inside
a 4 inch diameter ring with a single loop lampwire glued on the outside
The 4 inch sits inside the 6 inch......
Now look again at marco's last picture and see that he only drew the lampwires, just imagine the lampwires being glued to the tube rings as described....
it's easy......
regards
Robert
Earl
Hi All,
I am throwing another drawing into the forum, if it needs to be changed, tell me and I will change it.
Read all the comments from Otto and Ronotte and ECD_Mobius_Schematic.PDF
Regards, Earl
otto
Hello all,
finally. THANKS ROBERTO NOTTE - Ronotte
Enjoy.
Otto
