IPMM MAN-device for the proof of magnetic overunity.
Started by AnandAadhar, April 09, 2008, 07:58:21 AM
AnandAadhar
IPMM 20 - 14 nov 2012 Update : a few minutes of keyhole video just to show you the progress I have made last year with the IPMM project. What is seen is an improved cakra magnet rotor built from neodymium magnets which can push/pull twelve kilo's or more. The pendulum with four neodymium rod stator magnets driving it has been improved into what can be called a lever pendulum of four times the 3 kg weight weight of the disc including its inertial controller (counterweight). Two long connected pendulums give a thorough push to two shorter separate ones. The output under the disc is supposed to deliver sufficient torque to keep the long pendulums out of the middle, so that with their leverage a rectification of Space Energy can be achieved. What needs to be done is the final part that closes the loop. The actual bottleneck to prove or disprove the theory underlying this test is to make the snake bite its own tail. Closing the loop is the problem in this type of design. In previous versions this could not be achieved. This part took Finsrud twelve years to complete.
The theory goes that time energy - the expansive operation of the fourth dimension - manifests in the complementary relationship between gravity and electromagnetism that is controlled by inertia. What I am trying to do is to build a mechanical rectification circuit for converting time energy, the restlessness of the chaotic vacuum, into kinetic energy. If it works the existence of something like time energy, the supposed cause of universal manifestation, has been proven. Is such a rectification, just like that of DC current into AC current, possible? The basic idea is that macrocosmic and microcosmic spin is ruling all matter and that there is no reason to suppose that the laws of nature governing that spin would not be effective on the mesocosmic level of a table top experiment.
Vishnu Yantra is Sanskrit for ether machine. G.O.D. Refers to the Generation, Operation and Dissipation of the three basic modes of nature: creation, maintenance and destruction. The lever pendulum creates the spin, the rotor maintains the drive by its reaction force and the dissipation is taken care of by the feedback mechanism that must close the loop: that what Finsrud calls the 'vibrational feedback unit'. The machine in fact puts the Vedic Philosophy to the test of a threefold concept of time and space referring to these modes as the characteristics of the three primary gods of Hinduism. Hence the name.
The schematic of the setup shows the formula I at present try to validate with this test. There were many modifications of it in previous versions.
Youtube:
http://youtu.be/i5Vr4bVZcgk
For more information see:
http://theorderoftime.com/science/free_energy/index.html
Anand Aadhar free energy research pages: http://theorderoftime.com/science/free_energy/index.html
