Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
Hoppy
Quote from: a.king21 on November 13, 2012, 10:12:02 PM
My team has been to Tbilisi and watched the device for 4 and a half hours. I also posted the aquarium 2 video.
I talked with TK 2 weeks ago.
I've talked with Travis of the Travis effect and received top secret research papers. I've talked with Don from Magnacoaster, I've talked with Dave Lawton and Patrick Kelly.
What's your contribution?
What's the Travis effect got to do with the TK effect? The only similarity I can see is they they are both demo's in fish tanks.  :)
By the way, have you got the original high res video of the aqua2 demo from your team yet for posting here?
27Bubba
"I talked with TK 2 weeks ago."
Does Kapanadze speak English,.. or you fluent in Russian?..
Сергей В.
Привет a.king21
I know TK is very ill. How much time has left to him ?
Hope is good for any man and hope always die last, but i think you was putting to much hope to him. The reallity is very real and very simple. TK will never reveal secret he got. NEVER - even in the grave - NEVER.  It's kind of spirit which love only yourself and live only for yourself. He is special kind of PARASITE. Suppose he have billions of dollars for example control US Federal Reserve. Do you really think he will be revealed a secret than? NO NEVER.
Many great people had left in smaller or bigger way something to mankind. No need to mention Nikola Tesla who had gave all he had discovered and how much great inventions which are in NSA secret undergound vaults. Tesla had a Great Spirit - Open Spirit. Only in that way he can done all what he have done. After Tesla many of Great and Quality people did the same all over the world. But TK don't belong to them. TK belong the world of Soclial Parasites. You can be angry on this assert but you can't do nothing against the Truth. Nobody can't.
I can tell you for example the problem of Cold Fusion synthesis had been solved in Russia long time ago by only one man Ivan Stepanovic Filimonenko in 1957. 55 Years ago exist  Cold Fusion Technology which can bring mankind on the new level of existance. But dark forces fight against coz they know it will be their final end. So the battle continues ....
Read my article about Filimonenko here:
http://realstrannik.ru/forum/19-svobodnaya-energiya/68216-ivan-stepanovich-filimonenko-i-xolodnyj-yadernyj-sintez.html
wattsup
@all
Whatever.
Can I ask a simple question about Zeners so I can hone in on some real values.
OK so here is the background logic.
Hmmmmmmm, OK, so after the 2004 secondary you have this diode plate concoction (DPC) but regardless of that, the secondary will be about 1/6th the voltage of the feed at 6 times more amperage. So in TKs case with his ac inverter at 220 at 1-2 amps on the primary will produce about 36 vac at 6-12 amps (AC10) of which he is only drawing 0.6 amps.
That is the equivalent of three 12 volt batteries rated at 12 amps in series to get 36 volts of which you take 0.6 amps and feed it to the DPC and the DPC regardless of how it is connected, can only do two things with it being either a full or half wave rectification (DC10). So same punch but first is 2 pulses per cycle while the later is 1 pulse per cycle. That could give a pretty good punch if pulsed into a system. So this is the first energy available.
The other energy available is the AC5 line 220vac wire pair bypass line that goes straight into the tin can.
So together the AC5 + AC10 consume 0.6 amps of which I would postulate that the AC5 is only using 15% and the AC10 is taking the rest or 85%.
If the AC5 line is therefore taking only 0.09 amps at 220 vac makes 19.8 watts.
If the AC5 line is there to add to the DC10 output of higher amps, mixing both in some way to create a "massive shorting out of phase effect" across the load of light bulbs, I doubt if doing it with a 220vac meets 36vdc impact may be too much for such an effect and this will kill the inverter. So what if the two heat sinked components (HSC) are TO3 Zeners rated at 36v and 20 watts to match the 36vdc coming from DC10. Two Zeners could be in parallel to double the throughput while their two thin wires can create a light duty illusion TK would desire for the architectural merits.
So one question is how would a zener be used in such a case.
The other point is that the AC5 line not only brings AC into the tin can but it now perpetuates the AC neutral that can now go to the load and to any neutrally grounded sources. I always considered that the feed AC was isolated from the load but the AC5 line brings this to the load.
If the two zeners could feed a pulse to a point that also merges the DC10 line with the TK coil and the load, I think this mixing will make some good effect. Now how to test it?
So the second question is if the feed is 220 vac at 50Hz passing through a 36 volt zener, will the zener pulse at 152.7Hz (hence only during the positive of the AC5 sine wave)?
The regular ways of testing are producing regular results. It's time to try some out of the box thinking but I need some guidance on the zener thing because everything blows at one point and its always hard for me to stay below that point. lol
wattsup
Added:
I just purchased the following Zeners;
http://www.ebay.com/itm/370409131335?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
idzaza
Hi all.
I am writing first time here and in the forum I registered first time, I've seen some other forums too. I am Georgian, I heard about Tariel and his inventions I think it was year 2000. Let me tell you something. It was 90s when there are was serious energy problems in the country. Many of us had generators and car or some other types of battery powered inverter 12v  getting 220 volts AC from 12v DC. I myself have done many of these for my home and for others too. That was the period of darkness which continued till about 2004.
I've seen most of his video's and basically know as much as you about him. I heard about Tesla was about 1996-97, I think that should be the period Tariel started experimenting Tesla's devices. This is my opinion.
What I think is that he uses Tesla's coil, if you see his coil setup there is just a primary and secondary coil. the primary is the same as Tesla's device has but he uses as a secondary less wind and thick wire so he gets 220 volts.
The transistors he uses in 2004 video clip seems to me to be the same I used in my basic invert I think KT827a Soviet/Russian. Basically what this inverter had was microchip I think K561 which was giving from DC 12 volt ac -12v and +12 then had kt315 for each channel + resistor and going to the Transistors. Then two independent winds giving power of 24 volt in total to the step up transformer.
I do not think he is using many thousands of volts in the spark gap, it does not look like that, but he might be using high frequency. (Note: I do not know). I have not got all these theoretical knowledge you have, but from my little practice his device is not something very complicated I think. I have not done Tesla's coil or anything like that, but now I think he uses the power source for the HV transformer I used to use for the inverter.
For me Georgian is a first language, thus I know Russsian and English up to the level I can communicate.
The question I have is how much volts are in the spark gap and what frequency does he use? I guess I have a lot to read before I understand what is going on.
I understand what they are discussing in Georgian and Russian and can tell you that his devices are real. I heard and convinced that his devices are not fake, they are real and I think is simple to make. What he does is in some videos he just adds some othe components like inverter to power the the transformer which then powers the HV transformer I think. Also just to say If some one wants to complicate scheme would do so by adding lots of junk.
all these water generators, solar panels, diesel/petrol/gas - electricity generators are well known in my country at least to me and I am not an electrician, HHO too we heard about it and made but was not any efficient or convenient at that time.
I think Tariel just changed something in Tesla's coil set up and got result, mainly I think he uses less wind and thick wire as a secondary in Tesla's coil.
