tagor
Quote from: DaS Energy on December 02, 2012, 10:52:42 PM
Hello all,
From that I see in the video the heat of the electric arc occuring at the sparkplug causes the water to split into hydrogen and oxygen which then burns.
There is no question a lighting bolt (ie arc across the plug points) will split the water and burn the seperated gasses. However that tiny mist to the spark plug would need be greater in volume if greater forces are to be acheived.
Water powered engines work on the same principal of splitting water.  I would much llike to see how much wattage is required to do the split, and what pressures are obtained from the burning gases, so they can be calculated to KW or Horsepower.
Cheers Peter
this is very HV  and 500HP
look at this
http://www.overunity.com/11814/luxury-hydrogen-fuel-cell-boat-draws-electricity-from-sea-water/msg308596/#msg308596
- he was using "dry cells"
- he could produce an huge quantity of HHO (you bet he should).
- he generated 50.000 volts but that the use of this voltage was "complicated"
- he got his idea partly from the Internet
- he was OK to receive me and to "take me for a ride" but that I would not
   be able to see the engine (even from a long way off...).
DaS Energy
Hello Tagor, Ive been through all the posts and videos but cant get more information than uses X voltage which means nothing. Watts be the thing.  Real easy to use sea water and CO2 to make electricity. Royal Navy in the 18th Centuary trialed Ammonia, we replaced the Ammonia with CO2.
If you can score the wattage from his highly complicated thing. I shall post the generator, using no more than sea water and CO2.
Cheers Peter
tagor
Quote from: DaS Energy on December 03, 2012, 02:31:55 AM
Cheers Peter
yes this very secret until now
look at PESN , we have to wait until january or february to get more information
PS :
looking at the batery will be a good thing , but we can not !!
or buying a boat = 300 000 euros
DaS Energy
Hello tagor,
Thanks for the info.
Any child can take a dry cell battery and spilt oxygen and hydrogen out of water. All you need is two electrodes.  Doing it with sunlight alone was mastered yeasr ago by CSIRO Australia.  I thought by the carry on he was making, he had mastered how to get the electricity for free.  Which is what I am banging on about.
Cheers Peter
tagor
Quote from: DaS Energy on December 03, 2012, 04:30:39 AM
Hello tagor,
Cheers Peter
yes , but can you , easely , running a "more than 800 CV" motor ?
