increase OU of captret
Started by dequadin, February 21, 2013, 03:11:59 AM
dequadin
I have made the small scale of RE electric generator to light up a LED.
No battery involve at this time!
Energy from what we call "self charging effect", thats prove the RE does exist around us
http://www.youtube.com/watch?v=7zUKmH4YqVk
I will continue my research on this type of energy.
aaron5120
I tried my best to interpret your description of the modified captret device. This was done for the benefit of the fellow researchers here in OU.com in getting a visual idea of what you are currently doing. Sorry if the setup does not match closely to your actual connection.
You may choose to enlighten us a little bit more with your clarification. Thank you for sharing.
aaron5120
dequadin
Not really look like arron5120 mention.
The jar I call it R.E. Receiver, 9V battery involved.
You can only see 3 terminals on the jar, all the circuit and stuffs placed inside the jar.
The Captret is placed inside the the jar, the storage capacitor too.
I highlight the foil is placed inside and outside the jar, the foil outside is feed-back to the jar as antenna.
The foil inside is slightly negative and feed to a small circuit then connected to captret with a 9V battery negative terminal.
Another picture is the design of the scale-down RE generator that "without" involve any battery.
It weights about 1.3kg placed in a gift box, 2 terminals for positive and negative.
Without the Load, its voltage above 24V, when the output after shorted, the voltage will suddenly grow up to 4V instantly, and +1V/s,+0.5V/s,+0.1V, half-hour with grow up to around 24V
With Load(LED 3.3V 20mA focus light), its voltage around 3.2V with around 11~12mA(just guess by compare the brightness)
dequadin
Updates:
1. I find my sponsor for this research.
2. I have tried using joule thief to drain the energy from my tube, but this doesn't work(unstable voltage, what is the load for the transistor then?....using adjustable 3kohm, can't be tuned on the right spot)
3. new design is planning
Thanks all for the support
aaron5120
Now I see, you came here at OU.com with the intention of finding sponsors for your project.
Joule thief is a blocking oscillator, and is not a stable oscillator per se, its oscillation frequency fluctuates when the power source diminishes its voltage potential.
Choose other oscillation circuits if you want stable resonant tuning spot.
Good luck to your new design. We come here to share our projects for free.
