Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 1906 Guests are viewing this topic.
stivep
Revolution has began Free Energy exposed part2[/font][/size]
http://www.youtube.com/watch?v=Mk3ku_dBzBM
This one is not as good quality but is not screwed up/
Wesley
stivep
Wesley
elementSix
I have found in using a pancake coil transformer in res0onance with the excitation pulses of sine waves with the right capacitor.  I have gained around 2 amps.  I found this pic off of a website.  its using resonance with a neon sign transformer and the appropriate capacitor in resonance.  Only using between 50 to 500 Hz.  Just like TK said, in Green Box video, It keeps resonance between this coil and the other coil.  But no one will say anything, the words will just fly by.  It of course took me over 2 years to figure it out.  Use a spark gap too
Hoppy
Quote from: x_name41 on March 30, 2013, 04:07:39 PM
ok, so this works on the principle of electromagnetic induction where first bobin generated high electromagnetic field which interacts with second bobin with low electromagnetic field and from those two fields is formed much more powerfully third electromagnetic field. It is important to note that the output second bobin should have a less windings but filled with a thick wire!, order not to induce the high voltage since the we need a low voltage and high current. This is the static analogue of the mechanical electric generator!
Thanks for the explanation and links to the TK patent. I can see now that your circuits are based on this patent. Something interesting that I had not noticed when previously reading the patent, was that both the agent and the other applicant are shown with registered addresses in Turkey!
Zeitmaschine
So then which of these schematics above do actually work? The answer can't be none, because then the statement »this works« would make no sense at all.
Just asking ... ::)
