Successful TPU-ECD replication !
Started by mrd10, June 12, 2007, 05:12:47 AM
Quote from: EMdevices on June 20, 2007, 11:15:12 AM
Have you guys noticed what WaveWatcher said:
QuoteOne thing ran into another and I tied the pulse from one coil to another with some LC (no, not big enough mFd to hold a shock) to phase it so it is useful and next thing I know I have two small hacked RS transformers with PM inserted linked as one howling, audibly,  about 300hZ with no signal applied.
Note:   "RS" stands for RadioShack, I believe, "PM" for Permanent Magnet, and "LC"  for Inductor and Capacitor (to make a resonant tank and also change the phase a bit so it adds in feedback)
EM
Yes, makes me wonder,
if he has some kind of MEG self running device ?
Please WaveWatcher let us know.
Many thanks.
Regards, Stefan.
CTG Labs
EM
Sounds like Hendershott!  Looking forward to more info!
D.
chrisC
@Darren
Thanks. Yes, I was aware your simplified circuit was for illustrative purposes only. My understanding of SM's reference of using high quality equipment in the TPU research was that with these calibre test equipment allow one to monitor what actually was happening from the waveforms when, perhaps mediocre equipment may fall short. Case in point, the 'seed' can't be seen properly with a 20MHz scope and might be interpreted as hash whereas it was clearly discernable with a 100MHz unit. Here we are all trying to reproduce and understand the frequency and phase relationship of the 3 harmonics with limited ability to generate stable synchronous or asynchronous clocks and much less the ability to monitor what is going on wrt the mobius when most of us don't have 'proper' instrumentation!
@bob.rennips
Thanks. Yes, maybe we need a spectrum analyser to see the details when we are near being able to reproduce the magic effect?
chrisC
z_p_e
Quote from: ronotte on June 20, 2007, 10:39:40 AM
High all,
please look at Otto's mixer: what is implemented is not OR but rather a sort of 'WIRED AND'.
Have you asked yourselves what happen when for example the lower freq oscillator is in it's 1 level? Well the connected Mosfet's Drain is locked to zero level so locking the same for all the others!! (no matter what they are doing).
OR, or Wired AND. It depends on how you look at it.
I see the inputs as an OR, because a logic 1 on f1, OR f2, OR f3 will pull all 3 coils to gnd.
I see the AND part more in an analog sense, in that the supply currents from each "ON" FET switch will sum together.
It's open to interpretation I suppose.
Darren
ronotte
@Darren,
Yes, in that sense we are speaking of the same final effect which is important.
For what I've seen the 'Seed' is created by a sweet combination of the 3 frequencies and from the catalyst field produced by the Mobius loops which MUST accelerate any particles (electrons, ions...) that appear to be in the nearings (tested experimentally: if you increase the heath sink modules distance from the ring...the Seed disappears!).  Then saying how is the creation process is really for now impossible. I urge every body to think about this!
Roberto
