High voltage HHO by IronHead
Started by IronHead, March 08, 2007, 06:19:16 PM
s_c_engineering
a bandsaw works good too if ya gots one of them.... as would a hacksaw i think.  depends on how thick your steel is, i was using 24awg so a bandsaw blade width was poifect.....
hkyle
That would be HDPE (High Density Polyethylene)
here is a link to some stuff....pretty cheap
http://k-mac-plastics.com/hdpe-cutting-board.htm
Quote from: rapttor on June 20, 2007, 12:41:56 PM
I've actually got 2 Dremels, a rotozip.. oh hell.. a ton of pwr tools. I used my dremel alot until I recently picked up a similar unit but marketed in the wood working world as a cable driven chuck, that gives you much more versatility.. and it came with a foot pedal to vary the speed.
What is that material HKyle? Looks like either Teflon or Styrofoam.
My next step is 500+ degree hi temp gasket maker, that will seal the edges for sure.
sorry I'm not trying to drag the group backwards.
-rapttor
It?s easier to be forgiven than it is to get permission....
rapttor
Cutting board plastic cool, I didn't know the name of it... sweet
thanks man.
@ s_c yes I have a 14" Bandsaw, but it's got a 3/4 X 10tpi blade in it right now that's dull from all the AL I've cut, I need to change it up for maybe a 1/2 X 6 to 8 tpi.
My plates are 1/8th ss so they are just a little bit too big for a blade's width, but I think I'm going to try the circular saw, on a slide, then slice the big piece into the right widths.
-rapttor
Successfully Perpetually Failing at everything I do...
s_c_engineering
so have you guys tested hdpe cutting boards with koh solution? before i go buy some of this stuff?  jsut ordered some koh, all teh damn tweakers around here have caused the stores to stop selling it.  damn meth makers
hkyle
I haven't tested it with KOH but I have tested it with Lye and it works fine....I can't purchase KOH either....damn meth makers >:(
