Selfrunning Free Energy devices up to 5 KW from Tariel Kapanadze
Started by Pirate88179, June 27, 2009, 04:41:28 AM
0 Members and 1906 Guests are viewing this topic.
magneto_DC
Barbosa/Leal
Hi,
does anybody know where the load has to be connected to?
ariovaldo
[size=78%] [/size]Check this out. Just a test.[/size] The set up is a modified MOT, with a 120 volts in the primary and 2 turns in the secondary. As expected, I got high ( approximately 1000Amps) amps and low voltage.[/font]
The million dollar question is: How to speed this up? Use a high voltage? To add another transformer with more turns? To create a rotate magnetic field to extract the juice?[/font]
I got some ideas and I will work on[/font]
http://www.youtube.com/watch?feature=player_detailpage&v=x8Fo-rjD1ys
[/size]
Greetings
Zeitmaschine
Quote from: Gidfactor on August 19, 2013, 10:52:35 PM
Hoppy and zeit
http://www.youtube.com/watch?v=VAK0UgTr2CE&feature=related
Can this be verified.
Very interesting I thought no one got it to work... Hmmmm
Looks very simple it will make you laugh..
Cheers...
As the story goes, Tesla inserted the two metal rods and announced confidently, "We now have power" and then proceeded to drive the car for a week. Nikola Tesla's 'Black Magic' Touring Car
But maybe it should be slightly more simple anyway, because I don't see how this could fit in TK's tin can (or on a front seat perhaps).
er ... what about hidden wires in this one? ???
Hoppy
Quote from: ariovaldo on August 20, 2013, 09:34:55 AM
[/size]
Greetings
Yes, try extending your 2-turn secondary winding to a remote step-up MOT. You are unlikely to get sufficient voltage with the power needed to light mains lamps as TK probably used a heavy duty welding transformer with a high current secondary at around 40V output, but the principle of operation could be the same IMO. I think TK may have employed a 3-phase transformer in his 'Green Box' device and used its other winding(s) for shorting to get maximum lamp brightness. Also, try running a well watered earth return on the loop to simulate TK's radiator and water pipe earthing arrangement to see if this is feasible in this setup.
