222% Energy Conversion.
Started by DaS Energy, December 12, 2013, 09:57:10 AM
Quote from: DaS Energy on December 12, 2013, 06:18:44 PM
Bloke once saw an elephant and spent the rest of his life denying there be such animal.
Is that a refutation of my posting?  Or is it another off-topic, dataless, left-handed insult?
Please show how a number of "underunity" stages can be chained in order to produce an overunity result. Builders who have the knowledge and means to test efficiencies would really like to know.
DaS Energy
Hello all,
Follow the drawing.
Solid black lines define the containment vessel.
Solid blue line is the water moving out and the broken blue line the water moving back.
Red line is either air, steam or gas.
Filled in circles represent balls.
Filled in triangles are one way valves directing the water in direction of point.
Filled in grey black lines are small diameter pipes.
Requirements for build are pipes, an 82% efficient impulse turbine, a 60% efficient air, steam, or gas turbine, plus two DaS Valves.
Enough volume of air, steam or gas is required to rotate a turbine 360*. Having obtained that in the boiler, the hydro turbine is rotated 720* and the air, steam, or gas turbine is  rotated 360*.
The 164% efficient design can be attached to any air, steam or gas line without effecting its volume or pressure.
Efficiency rating of the turbines is that supplied by the maker.
Peter
