Reactive power - Reactive Generator research from GotoLuc - discussion thread
Started by hartiberlin, December 12, 2013, 04:34:12 PM
tinman
Quote from: poynt99 on January 06, 2014, 09:38:11 AM
I thought you had it sorted some time ago?
I have sorted the part where you add channel A and B,and get the math trace up on the screen,but still cant find where to read the result of the sum,other than a whole bunch of numbers that make no sense to me.
poynt99
Can you post a screen shot of A x B?
Maybe the result is buried amongst all the numbers.
poynt99
Quote from: gotoluc on January 05, 2014, 06:56:46 PM
Okay, something new learned!... DC coupling when wanting accurate math results from an AC source.
Not a problem. I will do that from tomorrow on.
Thanks for finding that one.
Luc
Well, you should be using DC Coupling for 99.9% of your scope measurements actually.
gotoluc
Hi poynt and all,
here is a video update with the scope set to DC coupling. I'm still questioning the channel 2 Inversion.
Can you please confirm which way it is and what is Watts used
Video: http://www.youtube.com/watch?v=gTJ8i5unIwQ&feature=youtu.be
Luc
d3x0r
from a ground base; (common/neutral), the probe on the outside of a resistor is positive for a positive current draw.
- load(+ side) - battery - (low, negative side, scope common) - CSR - (probe, high level is positive current) - (load)
Should not be inverted.  Inversion should be used if you're biased against the positive as the ground reference.
