Tesla's "COIL FOR ELECTRO-MAGNETS".
Started by Farmhand, April 21, 2013, 09:00:24 AM
conradelektro
Quote from: MileHigh on January 15, 2014, 03:52:05 AM
Some great clips from Itsu:
Pick-up coil for a pulse motor configured in parallel resonance:
http://www.youtube.com/watch?v=syxL4f2OsPg
http://www.youtube.com/watch?v=yNtnLAVk9Og
Pick-up coil for a pulse motor configured in serial resonance:
http://www.youtube.com/watch?v=K-avee5Z1oU
@MileHigh:
Would it make sense if I wind the bifilar coil with 6 wires like itsu (see the attached drawing)?
Itsu video: http://www.youtube.com/watch?v=syxL4f2OsPg minute 03:02
Greetings, Conrad
Hi Conrad,
You don't need to use 6 wires.
synchro1
Youtube quote from Dr. Steven Jones:
"Note that I replace the conducting disk with a bifilar pancake coil (BPC) wound with coax. Charge from the coil is collected through a Schottky diode on a 47 uF capacitor which held at zero mV for an extended time prior to the experiment"
Look at the identical "Synchro Coil" circuit Dr. Steven Jones is using, Schottky diode and capacitor in series with a bifilar coil! Take special note of the "ELECTROLYTIC CAPACITOR" with the testing probes attached! Ask yourselves what kind of results one could expect if someone rudely barged in and replaced his diode and capacitor with a couple of resistors? This experiment is practically identical to the "Synchro coil" except that the "Synchro coil" works from rotor excited magnet core flux, instead of the bipolar disk agitation!
Check out his video on the FARADAY'S PARADOX REVISITED BPC (Bifilar Pancake Coil):
http://www.youtube.com/watch?v=I3hXYSKxsX0
It should be clear that positioning the "Synchro Coil" in the flutter zone would cause exactly the same kind of magnetic fluctuation Dr. Jones induces in his BPC with his spinning disk! Dr. Steven Jones defies Faraday's paradox with this experiment, just like the "Synchro Coil" does. Take note of the importance Dr. Steven Jones attributes to the positioning of the magnetized disk in his video!
Milehigh and Conradelektro blatently kiboshed my "Synchro coil" test, went on to run DC current through a PMH coil then "curled their chimp lips back" with a "no locking effect" magic claim grin!
My worst paranoia is that those two staged that "Synchro Coil" failure to develop the coil in secret for commercial profit!
Magluvin
Quote from: Farmhand on January 14, 2014, 09:16:33 PM
I'm considering winding some spirals, I've never wound a spiral for a particular reason, I'm thinking I will make them physically as large as is practical for me, and able to take fairly high voltages. Looking forward to all results, it is interesting stuff.
When i was studying car audio, and audio in general, an interesting thing I found along the way may apply here.
When you input a freq into a speaker, that has an audio wavelength that is shorter than the diameter of the speaker will tend to 'beam' from the cone surface. Now the wave length Im talking about is the distance in air that a single cycle of the wave is. Like if you have 2 tweeters in front of you at a distance, then start to bring one of the tweeters closer to you say at about 10khz there will be a distance as the tweeter gets closer where the 2 waves from the tweeters will be 180 out of phase and you wont here it any longer. Then move the tweeter closer to you, just double the first distance and you are back in phase. Like 3khz is around 3in or 6in to be out of phase if I remember correctly.
So I wonder if a beaming effect could be produced with a pancake coil.  Or even if it would be useful. I suppose greater distance to a receiver would be an advantage. Would probably have to be huge in diameter for even very high freq.  Would have to look that up.
Just a thought I had at work before lunch. Dont know if it has any relevance.
Mags
tim123
Quote from: synchro1 on January 15, 2014, 11:10:04 AM
Synchro, mate...
1) That vid above by Stephen Jones, has to be one of the worst conducted experiments I've ever seen... It's terrible.
2) The experiments you keep ranting about are *so easy to do yourself* - that your ranting is ridiculous.
3) Your attitude towards Conrad & MH is out-of-order!
Just do the damn experiment yourself. For goodness sake!
I'm beginning to be quite irked by people who are not prepared to do their own !$%&# experiments!
