Wasif Kahloon's Magnet Motor
Started by NTesla, January 29, 2014, 12:31:49 AM
memoryman
Mark, I have controlled that 'run-away' by sprinkling some pixie dust onto the shaft. A provisional patent for this process has been applied for. I am working on a fully automated delivery system for this. Licenses are available at a reasonable cost (I used J.P.Rohner's licensing model).
Please keep posts serious.
deanc5000
I cant believe there is even a conversation about the reality of this machine. This is a movie prop and nothing more. The real mystery here is why bother with the hoax? What is to be gained? This does more harm to the real free energy experimenters than good  and turns it into a joke.
Its easy to see its not real. There is no rotor in the generator. There is no rear cover on the generator which is necessary to hold a rear bearing which is also missing. The generator shaft is fake. Its just a short piece of rod that is connected to the spring coupling. The hidden 220v motor is probably in the front of the mag motor.
T-1000
Quote from: TinselKoala on February 03, 2014, 08:36:44 AM
Or simply ask him to do this:
Run the full system as shown in the last video.... then uncouple the shafts. Just take off the hose clamp and peel off the electrical tape coupling the "motor" to the "generator" and show the "motor" now running along by itself.
Now stand back and log the excuses he emits as to why he cannot -- or will not -- perform this one simple demonstration that would take five minutes to set up.
The better offer would be to make clear statement in fb for him on public page - to disconnect all electric parts including generator and attach some heavy weight to lift up right on magnet motor shaft. He can control easily when to stop so the weight won't be swinging around shaft after rope is pulled.
Then serious engineers could go there to investigate this setup.
It's a funny sort of generator all right.
Quote from: mscoffman on February 02, 2014, 04:52:32 PM
What is really needed is a mechanical shaft to shaft coupler with a torque
comparator and shaft direction measurement that produces an indicator
arrow display that indicates which direction the torque vector flows to.
It's just too easy to have a generator be a motor or vice versa.
(snip)
:S:MarkSCoffman
Well, we sorta kinda have just that, in the coupling spring, don't we? Does it twist up, or does it untwist, when the device is running?
