Gotoluc Locked out of Energetic Forum
Started by gotoluc, March 23, 2014, 01:24:42 PM
jbignes5
I'm sorry to hear about your tiff with Aaron. But I do welcome you to the club!
Now lets see what your are doing here.
You are using a standard winding which is wound  back and forth. A back and forth winding will always create an eddy. If you want to use multiple wraps then I suggest using a mono direction winding. What this means is going from one side of the core to the opposite side then a straight line back to the left hand side to begin another wrap. This way the channel that is made is not fighting itself in the wind.
You could always use a bifilar wrap that should work better. The thing there is to keep the bifilar wrap single layer. If you want more current then use a thicker gauge. More voltage then use a thinner gauge.
I think also you are too close to the core with the magnet. Also you need to use a balanced approach meaning you need two sides of the core so that the pull is balanced from both sides. This way any reaction will also be balanced, especially when pulling current from the windings on the cores.
Although this approach is similar to my approach it is very different than what I am planning on doing.
My circular core is 10.5 inches across. It is a field core fed with high voltage impulses. The Rotor is a two phase generator setup and is designed to transform the high voltage fields from the field cores into low voltage heavy current. Of course this will create a huge magnetic field in the center and will connect to the field cores in such a way that it will cut the high voltage winds on the field cores. This in turn will generate even more high voltage and increase the high voltage fields around the generating cores coils. The prime mover in this case is on the rotor of the generator and drives the rotor to spin the rotor coils in this high voltage field, generating even more. Now here is the trick. When you design the field coils to go against the rotors turning it will generate even more as well.
The design can be seen here in it's entirety:
http://www.teslauniverse.com/nikola-tesla-patents-390,721-dynamo-electric-machine
A few notes here. The exciter can be omitted for prototyping purposes. But should be added as a final design. The exciter needs to have spark gaps between them and the field coils of the generator section. This is to give it impulses.
In the patent it shows a belt going to the rotor of the generator unit. It doesn't need to be there if the motor in this patent is connected to the same shaft of the rotor.
The field coils of the generator section should go in opposite direction then what the motor is spinning the generator section. This is to increase the generators efficiency at lower speeds. so that the motor component doesn't stall at those speeds.
Other design features can be incorporated into this design after the prototype is tested. One being if a segmented core would benefit the generator section. I'm of the opinion it would do the opposite. Seeing the field core is not used directly in the high voltage field cores. They only are used to guide the heavy magnetic field from the rotor back to the field cores to generate additional high voltage. They also are used mainly for centering the rotor within the field coils. Tesla said that even the most sloppily created generator section would work perfectly due to this centering effect of the rotor inside of the field cores.
I am stalled in my build because I am in the process of getting myself back on my feet so to speak. I have gotten an update of my condition now. I have scoliosis with degenerative disk disease as well. Got to move to a more friendly house for disabled people. I was approved for a wheelchair but have to move to accommodate the wheelchair. When I finally get my family moved and my wheelchair in my possession then I will continue down this path. Until then I am working in my bed, so any progress is very slow going atm.
Take this for what it is, just some friendly advice.
Jbignes5
gotoluc
Hi everyone,
please be advised that my ability to post at the Energetic Forum has been reinstated.
A member contacted Arron and asked why I can no longer post and the below (bold) is Arron's reply.
He should be able to post now. It is set to a normal registered acct now. I don't know how it changes unless another moderator did it.
Aaron Murakami
Luc
synchro1
Hooray!
@Tinselkoala,
Check out the Chiral Disk Scalar wave thread!
gotoluc
Thank you Jbignes5 for your post and details.
I hope your situation can improve and you can find a comfortable home.
All the best with your experiments
Luc
No need for this topic any longer so it is now locked
