selfrunning mebius coil
Started by jonifer, July 12, 2007, 03:38:09 AM
BEP
There is a pretty good explanation of this at www.efir.com.ua. Use google to translate if needed. This falls in the realm of the flat TPU and Cook coils (my opinion).
pese
@BEP
its a lot of datafiles , so i can not follow.
pls copy the google translation from your PC and copy this here in tge tread,  so hundreds members must not this problems.
G.P
zilk
this is the topologically changed capacitor on the basis of Moebius's sheet
interacting by its own electromagnetic radiation with the electromagnetic and gravitational field of the Earth, it comes in the rotation in accordance with the theorem of Deriav ???
the cylindrical capacitor is next located
BEP
Sorry,
I didn't use Google to translate. Google usually does a good job of translating this dialect into English. With my connection speed it would take several hours to do the job for other members.
Instead try googling "efir.com.ua theory". They have nice graphics in that speak and may also have same in English as that is standard practice for presenting papers.
>>>edit
If you don't speak it try this...
http://translate.google.com/translate?hl=en&sl=ru&u=http://www.efir.com.ua/rus/a.php%3Fr%3D4%26d%3D10&sa=X&oi=translate&resnum=2&ct=result&prev=/search%3Fq%3Defir%2Btheory%2Befir.com.ua%26hl%3Den%26sa%3DG
kames
Here is a rough translation in English.
Two people are talking.
1)   Here is the suspension. Here is a prototype of a non-rotating suspension.
2)   Cylindrical capacitor.
1)   Yes
2)   And this one is changed topologically
1)   A capacitor based on a mebius cross, great German physicist and mathematician
2)   See, it is trying to rotate. Let?s start. Let it go
1)   Okay. It started. We can reduce momentum of inertia and it will start rotating even faster, ie, suspended on a longer thread.
2)   You see that a cylindrical capacitor is not moving but a capacitor based on the mebius film/tape is rotating by interfering its own electromagnetic transmission with the electromagnetic field of the earth, it makes it rotate.  It is based on the Viam?s theorem (not sure about the name, not clear sound).
1)   Density of the earth magnetic field is about 30 amper/meter. Gravitational field is about 9.81 m/sec/sec. Electric field is about 130 V/m. So, if you are interested, you can even calculate the frequency of rotation.
2)   One can even calculate a work performed by it because it is suspended on a triangle like shape thread?
1)   Can we see the threads well?
2)   Not really. Okay, now I can see.
1)   And it is rotating.
2)   So, will we twist the threads up to a (black) marker?
1)   No problem.
2)   Let?s twist it up to the marker and then we can unwind it.
1)   If you lower it, it will rotate even faster. It will rotate forever.
2)   Now, I am asking you to stop it.
1)   Stopped.
2)   So, as you can see it wants to rotate again and in the same direction.
1)   Now it is not rotating (stopped).
2)   I.e., the ring can be rotating in an opposite direction if a (mebius) ring is connected/built in a reverse way.
1)   Yes.
2)   This is a right hand rotation but there is?. (end of movie).
Kames.
