dieter
Isn't the shell-core also a coil, a one turn short circuited one?
Real Boots
Dieter;
The inside top edge of the shell is insulated between the two pieces with electrical tape to prevent the shell from as you mention being a shorted turn itself.  Also I insulated the plates of steel that comprise the shell from each other with packing tape to reduce eddy current losses which will eat up power like crazy and produce heat in the shell if not prevented.  I just realized that putting the main secondary wires through the shell in the way I did must be causing losses as well, should have current leaving through same opening that it enters or else you have shorted turn in essence around the wires in the shell itself.  In power panels you always run neutral and hot through same opening in steel enclosure or else metal will heat up around wires.
dieter
Boots,
Ok, I see. People often use a steel, copper or alu pipe as a core substitute, not knowing about that (and the enormous amperage in such a coil). Didn't know about the Hot/neutral wire thing tho.
When will you have the two channel scope?
Real Boots
Hooked up scope last night, very disappointed as i only get 10 deg phase angle between current and volts on input with 120w output at 120vac out into two 60w bulbs.  Power calc gave 158w in with 120w out.
Tried to compare phase of input volts to output volts with same 120w load but it appears to be in phase or 180deg out depending on polarity I connect scope probe.  Tesla patent mentioned phase shift but I am not seeing it at all, anybody know if tesla actually built the transfo described in the patent?
Perhaps if I could run it at 800hz or something phase shift would appear?  Any ideas on this are appreciated.
-boots
Magluvin
Quote from: Real Boots on April 15, 2014, 10:23:07 PM
-boots
Hey RB
I used to follow here but it died out.
What I remembered was that the input needed to be variable to adjust the phase shift. If the input is to strong, on a particular build, not much phase shift as it over powered the shielding of the shield. And too little input, no output at all, due to not being able to produce flux beyond the shield. Do you have a way of varying the input?
I believe Tesla said the the transformer needed to be designed for a particular input to operate properly. So if you have it built already, then you need to adjust your input to match that build. That is why Gabriel used the toaster in series with the primary, as it happened to work as the input adjustment needed for his build. ;) Freq should not be to important, just not too high for the inductances.
Mags
