Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
NickZ
  Johnk1:
   Yes, you are correct.  That was discussed in Akula's later videos.
   But, the circuit that I refer to is Akulu's first one, where he mentioned what Wesley translated as the "secret".
As being or meaning Earth magnetic resonance, at about minute 8:30, or so. Then Akula later switched to another source theme entirely in his later videos. His may have been the result of some advice from elsewhere. Though he showed no proof of any core decay or copper decay caused by NMR.
  As I understand it, the circuit has to be tuned into the Earths magnetic resonant frequency, for any extra energy to work in his device. Of course this could be wrong, and it may be that every circuit will be a little different, and will resonate with the Earth frequency at a different frequency yet, to achieve this higher output. In any case it is no small detail to be overlooked.
  T-1000: Akula's first circuit is not much more complicated than what Grum is currently working on now, though the coils are much larger and output is much higher on the first video.
  Grum:  Thanks for the videos,  sorry I can't be of any help with this one.  Good luck with it though.
   I will gladly build that circuit also, once someone can replicate it and gets it working right.
John.K1
NickZ
About that tuning to he earth magnetic field resonance - That's sounds more like an SM's  TPU.  What is the resonant frequency of the earth's magnetic field?  Or, are we talking about Schuman's resonance frequency? - in any case, there is quite wide spread of frequencies from couple Hertz up to dozens of kilo Hertz. Exremally important is here the modulation and de-modulation of the signal. But i think it is a little bit different story for different threat ;)
Back to the -Akula's fonar (torche) - Somebody here has said that the most important are coils. I would say most important is the oscillator. You can tune any coil to its sweet spot. But if your oscillator has not sharp rise and end characteristic, you will get nothing, even with the best coil you have ever made  :)
Well, we have good oscillator and we can get some nice spikes on our coil and what else? How we gonna permit that energy for next loop?  Capacitor?  You can charge your capacitor with high voltage peak from your coil.  I have done this test many times. One two short low voltage impulses and you have couple hundreds in your cup which blink 220V bulb.  I was thinking to make a generator based on that principle, but because the caps they have quite slow characteristic of discharge time I would need something like 25-30 cups properly timed- possibly programmed Arduino UNO.  For lighting just couple LEDs,  two cups could be enough I guess? -  jut my flow of thoughts ;)
NickZ
  Ed:
   Thanks for the links to the replication.  I had just watched that video, just before you posted the link. I don't understand much of it, but I can see that he does disconnect the battery, and the circuit continues to light the led. Great.
Good to see that.
  John: Not only SM mentioned it but Tesla discovered it, and Kapanadze, Akula, Dr. Stiffler, have possibly made use of it, and others as well.  I don't know if the Schumann resonant frequency is the same as what WE are looking to tie into, or not. That is what needs to be looked into.
  Dr. Stiffler mentions a frequency that he would tune to, but it was not the same as Schuman frequency. But, it was a frequency that would produce the highest peaks on the scope. All his three coils were then tune to that particular frequency. Somewhat similar to what Akula was showing in some of his videos.
In any case the idea is to tie into an already existing Earth magnetic field vibrational frequency to resonate the circuit with. This can vary with the particular device, as well as the conditions that produce that field. It may not be a fixed steady vibration, as it can vary with atmospheric conditions.
   Otherwise the conventional electronic laws will prevail,  as most have found.
  In my set up even the slightest frequency adjustment can cause the circuit to lose resonance. A proper feed back path is what I'm currently working on now, which to me is the most important aspect.
   One link on the subject:
   http://www.earthbreathing.co.uk/sr.htm
