Akula0083 30 Watt Self Running Generator.
Started by Grumage, March 06, 2014, 12:29:06 PM
EMJunkie
Quote from: EMJunkie on April 23, 2014, 05:30:31 AM
Hi All,
IC's and parts of the Circuit are attached, I don't see the Half H-Bridge chip on the board? Anyway we work with what we have currently. See the Below Zip File!
This info is from: Free Energy April 2014 Akula0083 Lantern No3 - Appears to be the same circuit.
All the Best
  Chris
P.S: For those that have not read my previous posts, I think you may find them worth a skim over, please read if you get time as the information has taken me a long time to put together.
Hi All,
The above information I posted may be an entirely different circuit! On further investigation, I believe they, both IC Chips are TL494ln but I cant be certain of this.
All the best
  Chris
Acca
 The missing clips are still on the Akula YT channel, you must have the link to wach the clips..  some clips are now re-loaded to to different channels.. so they are not on the Akula channel..
I will link the Russian forum on this device here below for you, as well as for others. This is in Russian, if you copy the link then paste it into the google translator it will translate the whole forum in to english
http://realstrannik.ru/forum/48-temy-freeenergylt-antanasa/134845-akuly0083-fonariki.html?limitstart=0
Weslay video translation of the Akula0083 device below.
https://www.youtube.com/watch?v=Lpx1SJdXnmo
Dis-Assembly bt Akula0083
https://www.youtube.com/watch?v=J-hBXaev5IQ
https://www.youtube.com/watch?v=91RNTyFTWS4
https://www.youtube.com/watch?v=pUW-3yXQIWQ
Atomic self-destruction is now "real" as Italians have discovered in 2007. Using ultrasonic energy they broke apart ferric-chloride salt and released neutrons using very low power.. Ferrites (micro size) in a ceramics don't have a lasting a mgnetic field and it's properties can be made to induce a "spin wave" in the Ghz.  range. One can collect the electrons in the nodal points this way. Akula has found a way.. in the lower frequency's.. This energy extraction is atomic in nature.  link to "Piezzonuclear" effect..
Why Iron?
From the point of view of the well known nuclear fusion and fission, Iron is certainly the less indicated nuclide to be employed. The reason of this statement can be found the diagram reporting the binding energy per nucleon as function of the atomic mass number. In this diagram Iron has, in sign, the lowest binding energy, which means that its nucleus is the most tightly bound. This means that, starting from it, both fusion and fission are endothermic processes, or in other words, that, even if the conditions for them to take place were created, they would not begin, since the resulting nuclides would have, in sign, a higher binding energy, which they should absorb from the environment. This is perfectly true in flat spacetime. Conversely, in a deformed spacetime, piezonuclear fusion and piezonuclear fission can easily take place for Iron as well, and moreover this nuclide, thanks to its higher binding energy per nucleon, reaches and overcomes the threshold more easily and above all in less time.
https://www.youtube.com/watch?v=6IZ34Wwa-AE
Here are posts from this forum from 2009 about "Piezonuclear"  (Italian term)
http://www.overunity.com/8503/ultrasonic-piezonuclear-reactions/#.U1eRxayLN8U
Acca...
MenofFather
EMJunkie
Quote from: MenofFather on April 23, 2014, 06:49:14 AM
Eihehehegeygey, I could not open this zip file.
Hey MenofFather,
I think its not the correct Circuit anyway. I have attached pictures.
All the Best
  Chris.
@Chris:
Div B = 0.
The "Bloch Wall" is a characteristic of your measurement system, not the magnetic field.
