3v OU Flashlight
Quote from: lost_bro on April 30, 2014, 05:58:51 PM
OK,  just to clarify from the attached PDF file posted earlier:
take care, peace
lost_bro
OK, using that formula I also get 48.4 kHz, which makes a lot more sense and agrees with the result Gyula posted. Units are important!
Thanks much.
However.... I am pretty sure that formula is for a one-piece toroid. The fact that we are all using multipiece cores will probably screw that up.
Vortex1
The schematic was derived by a couple of fellows at Overunityresearch, I may not be at liberty to post their detailed work. I will check in with them, or since they read here,  they can chime in.
I'll see if I can post you a link: http://www.overunityresearch.com/index.php?topic=2420.msg38115#msg38115
The heatsinks are just insurance should I get into a saturation condition when I hook up the inductor, never hurts to have a little extra heatsinking, besides if this doesn't work as advertised, I would like to use the driver for other experiments. I will also be driving some larger ferrites, perhaps from a power supply so I can watch the power consumption as I tune.
I used 220 ohm load resistors so that I could observe the switching without a lot of ringing etc, it is just a first step to see if everything is working correctly, then I will build the rest, including putting in some of the transient protection diodes and a properly wound and gapped ferrite core, MnZn type.
I know about LED's non-linearity, they are not necessarily the only devices I will use as a load test.
I am well aware of the limitations of a 9 Volt battery, and I do not expect any serious overunity.
The Miller clamps are specified as 2n3703, but faster devices could be used if needed.
I'm using IRF530's because I have them on hand, 14A 100V, nanosecond switching ability 0.16 ohm rds(on)
Should I perhaps not be posting here? I haven't done so in a few years but was very active in the past.
lost_bro
Quote from: TinselKoala on April 30, 2014, 06:26:52 PM
Good evening TK
Yes, you are correct... It is for a Toroid.
I guess I just wanted to expose the fact that the anecdotal information of * Core self-destruction* is not based on Fantasy or Imagination but does has a * rational * explanation.
We have to start somewhere with this.....
take care, peace
lost_bro
Cap-Z-ro
Quote from: Vortex1 on April 30, 2014, 06:44:26 PM
I used 220 load resistors so that I could observe the switching without a lot of ringing etc, it is just a first step to see if everything is working correctly, then I will build the rest, including putting in some of the transient protection diodes and a properly wound and gapped ferrite core, MnZn type.
Glad You're back V...its been a while.
I look forward to reading more of your posts.
Regards...
Vortex1
Quote from: Cap-Z-ro on April 30, 2014, 07:33:00 PM
Regards...
Thanks Cap, yes time flies......
