Akula0083 Light No3 - Dual TL494
Started by JohnnBlade, May 08, 2014, 11:34:00 AM
alejandroguille
MarkE
Quote from: alejandroguille on May 15, 2014, 09:23:48 PM
Anyone have the pcb?
I don't.  Akula hand wired his prototype.  I think that JB reverse engineered from photos of the prototype and or correspondence with Akula.
MarkE
I threw together a PCB design using the free tool express pcb.  www.expresspcb.com.  You can use this as a guide for a layout that you will etch yourself, or order boards from express pcb.  I replaced D3 - D5 with a second high speed diode.  I also added C6 - C10, more 0.1uF capacitors to decouple the stray inductances.  The switch connection is through TB5.  The flyback transformer connects through TB2 - TB4 left to right.  The dot orientation of the windings is marked in the silkscreen.  The power input is through TB1.
ETA: I found a mistake in the artwork.  TB5 pin 2 was shorted to the ground plane.  The fixed artwork is attached along with the updated schematic with the changes above.
alejandroguille
Quote from: MarkE on May 16, 2014, 02:46:57 AM
Thank you very much for answering!!!
and thanks for posting your updates so we saved time assemble.
JohnnBlade
in my tests i have seen that the IRF540n mosfets are better to use.
Greets JB
Quote from: MarkE on May 15, 2014, 06:23:16 AM
You should not have the collapses that you see.  I suspect a crossed connection that is not apparent in the schematic.  Disconnect MF2 and see if the circuit operates reasonably.  Then reconnect MF2 and disconnect MF1 and do the same thing.
I have redrawn the schematic here.  He only has a clamp diode on the MF2 drain, even though he should have one on both drains.  If your goal is to model what JB built then I would start with his schematic.
He's using 1N4007s where their long reverse recovery are going to cause problems:  D3, D4, D5.  The rig in his video looks like it has a lot of undesirable stray inductance that is good for blowing up MOSFETs.  Q1 and Q2 in the schematic are damn it alls as shown.  I have reversed the emitter and collector connections so that they will do something useful.  I don't know how his board is wired up.  With Q1 and Q2 wired as in his schematic, MF1 and MF2 turn off much more slowly than as I have drawn them.  Turning M1 off really fast without protecting it with a clamp diode is a risky affair.  I recommend adding a HFA08TB60 from MF1 drain to V+ the way that D6 is connected to MF2.
