ENERGY AMPLIFICATION
Started by Tito L. Oracion, February 06, 2009, 01:45:08 AM
Cadman
Quote from: a.king21 on June 16, 2014, 10:26:53 PM
Her's how to do it. That's why I know Tito is telling the truth unlike the ignorant who unnecessarily criticize him.
I've replicated it.
It works.
http://www.tuks.nl/pdf/Patents/Benitez/GB191514311A.pdf
Look at the first paragraph on page 2 ......tum-ti-tum.....
a.king21
Just curious, did you use one of these along with 14,311? Number 17,811 or 5591?
You know, a Benitez patent was one of the first I ever tried to replicate. Of course I failed then but now that I have studied a bunch of these old devices and studied the forums I think I actually understand these Benitez devices. :)
a.king21
Quote from: Cadman on June 17, 2014, 10:41:30 AM
a.king21
I've dismantled my replication because it was not cost effective compared to solar panels.
Also I was concerned at the heavy "breathing of the car batteries when I upped the power draw to 300 watts.
I ran the device for a week with manual switching, always drawing 11 watts mains light and occasionally powering a 300 watt motor generator setup and occasionally powering a 12 volt car electric kettle. After a week the battery voltages were the same as at the start.
The key is what  Benitez says.  He is very clear.
I used 2 car batteries and two HGV batteries in my setup. I used a 20 watt 1:1 trafo and a motorized Tesla switch for the interrupter.  The cap was a tiny 6kv cap.The circuit is the simplified one in Patrick kelly's book. I told him about my replication and he published the Benitez stuff. You need a big trafo or it won't work. Maybe a microwave oven trafo will work. You won't get a simulator to work because they can't simulate a spark gap or Tesla switch.
One more thing: Each switch of the interrupter generates a high mhz frequency. Your cap and trafo have to handle that to get the ou. Maybe a mot is too slow.
a.king21
Quote from: Magluvin on June 17, 2014, 12:10:03 AM
Hey Aking
Can you show the replication?  I deleved into this sort of switching in simulator. In ideal world, the switching was able to move currents back and forth through the caps/batts with no losses. But as soon as you introduce a load in line, the voltage drop across the load screws everything up.
Even tried transformer loads with additional inductor in series on the sec, but that voltage division of any sort kills it. tried this, tried that.
So we are still back to what way to amplify energy.  Not 'amplify' like an audio amplifier where there is no free lunch. There needs to be a key device that gives more than went in, simple as that.
Tito keeps saying more coils, more output.  But how can they all add to the output from 1 input without increasing the input? Or by adding more coils(output I assume), do they not deplete the other coils of their output potential?
If not so, then it must be that each additional coil must be some distance away from the others as to not affect them.
For me, there is just not enough to go on yet. Have had to concentrate more on work. This was taking way too much of my time, so work suffered a bit.  I had to change that. I hope it all works out some day.  Cant say for sure if it will.  Weve teased about 3 years.  More like about 6.
Ill still be around a bit.  Good luck.  ;)
Mags
My advice is to read all the Benitez patents. The answers are all in  there. I've spent hundreds of hours deciphering the old English. Benitez had 4 patents issued. In those days you had to show a working model.
Bob Smith
Quote from: Tito L. Oracion on June 16, 2014, 08:14:14 AM
Yes! that is very correct. and from that technique we can start our device. :) 8)
Yes! If one were to induce a potential difference into a coil consisting of parallel wires, each dumping into separate caps, which would in turn dump into a single capacitor and a few more in series... Wow, that would be quite the jolt of electricity, wouldn't it?
What if one had an antenna that was capable of powering a joule thief, and say.. a secondary from the joule thief kicking those parallel wires in the coil...
Doesn't have to be a JT; maybe just a computer fan.
Just thinkin' out loud.
Bob ;)
Tito L. Oracion
Mags
YOU ARE STARTING
AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!! >:( >:( >:( >:( >:(
WHAT KIND OF KIND ARE YOU!!!!!!!!!!!! >:( >:( >:( >:( >:(
WHAT DID I DO?, WHY ARE YOU DOING THAT AGAIN BRO? :(
AM I GOING TO STATE OR REPEAT ALL OF MY REASONS AGAIN?. :( :( :(
SO YOU MEAN UNTIL NOW YOU WERE BEING TEASED. YOU MEAN A BRILLIANT LIKE YOU BEEN TEASED FOR 3 OR 6 YEARS? :o  WOW
YOU @#$@#$%#@$%#$%$%^% >:( >:( >:( >:( >:( >:(
It is so sad for me to see again this kind of attitude to destroy someone using this clever brilliant kind of thinking huh.  :P
Conditioning every ones mind. A Judas attitude! >:(
WE ARE JUST THE SAME LEARNER HERE! I DID NOT PROMISE TO GIVE ALL DETAILS I'VE DISCOVERED! >:(
OK I'LL REPEAT THAT IS NOT TEASING THAT IS MY WAY OF TEACHING! GOT IT! >:(  YOU @#$#@$ >:( >:( >:( [size=78%] [/size]
I THINK I'M OFF THE POP CORN :)
