Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
gravityblock
Quote from: TheoriaApophasis on July 19, 2014, 06:56:51 PM
I agree in premise,  ;D ;D Can call a rose another name, its properties are the same.......
however CANNOT agree definitionally
, because all it does is PROP UP the ENORMOUS BS of Atomistic "unicorn particles" that make up the bread and butter of the Cult of Quantum.
GR and QM are 100% no different than ancient Greek Atomism.
To make any cultist of GR or QM twitch like a worm... ask them to "define a field"  ;D ;D
You said:
""""You don't believe in photons, electrons,""""
You dont get it.    A: what I "believe" makes no matter, what  IS , is all that matters.
You cannot keep using and evoking forth the PANTHEON OF PARTICLE BS  (of GR and QM), all it does is "feed the beast" that the Universe is an OCEAN of pixie-dust and unicorn "magic" particles  ::) :o
No such pixie dust nonsense, these are mental excreta concepts from GR and QM.
Have you even READ the  horsesh*t that comes from fools like  Feynman (and the morons like him) to explain magnetism and action at a distance  ??? ??
   ;D ;D
That Feynman and others have declared (as he has done in his mystical book: QED strange theory of light and matter) that
magnetism is mediated by "virtual photons" is no different than the Pope declaring mother Marry as healing a sick child from a
pendant worn at the neck. Humanity has placed, as dept. chairs in countless universities and likewise, heads of mathematics and
physics, people who are quite literally insane, are deep thinkers, but insane ones. The insane asylums of the world are full of genuinely
deep thinkers, however it is not for sake of deep thinking they are locked up and away from others! So, taking a cue from Quantum
mysticism we then ask the expert (fool) relativist "since you declare magnetism to be mediated by 'virtual photons', what is same?".
Answer received? Yes, here we have it: "A virtual particle is an abstraction, which facilitates in calculations and understanding, the
term is very vague and loosely defined, they never appear as inputs or outputs of experiments, their existence is questionable at
best,...however they are very useful in rendering concepts and making equations balance out". Well, insanity has been reified, at last!
Time, like SPACE, is a POSTERIOR to fields.    Time is just another human perceptual SKR3W.
Time, like space "does nothing"  "acts on nothing" and "causes nothing".
Induction between fields extrapolated (wrongly) as = TIME is wrong, even the ancient Greeks knew this fact.
Like the world FIELD (Khora), people throw around the word  FORCE   ;D ;D ;D
Force = tension = induction = field interactions.
Reifications of attributional properties of ONE PRINCIPLE (fields [Ether modalities]) is only a convolution of simplex truths of how nature works.
There are no "lines of force" .....polarization is by definition a force of Ether pressure gradients WITHIN which space is present and therefore SO TOO IS FORCE present.    There are no forces in space, there is SPACE created in a field which translates INTO force as fields generate, terminate, move divergently, convergently, centrifugally, centripetally etc etc etc
charge / discharge   on and on.
Even Plato and Plotinus warned about reification of Xaos (space).   Its a necessitated (ananke  GREEK TERM) attribute of fields (Khora/ Chora).
Like I said, I don't agree with the Copenhagen probablilistic interpretation of quantum mechanics.  I also don't care too much about Feynman.
Time is motion!  In this video of a "high road low road race", both paths start at the same height and end at the same height, so gravity doesn't provide either path with an extra advantage (The net fall is the same for both cars).  However, the car that travels the greatest distance wins the race!  The shortest distance between two points is a straight line, and the shortest Time between two points is a curved path!  Mass travels faster on a curve than it does a straight line.  In reality, it's a rectilinear motion through space.  All that exists is the impulse that is applied to the body in space and imparts momentum to it.   The impulse is the product of the force and the time for which it is applied .  Without motion, then there is no Time for the force to impart momentum to it.  Without Time, then there is no force to impart momentum to an object, thus there would be no motion.
Gravock
SeaMonkey
Quote from: gravityblock
As demonstrated in the experiment it certainly can.  The
steep initial decline and its gravity boost are helpful.
TheoriaApophasis
Quote from: MileHigh on July 19, 2014, 08:00:08 PM
People like you like to use the term "pressure" all the time but the problem is that 99% of the time it is meaningless.
Since you do NO experiments, I suggest you put your hand between two N55 gauss  2x2x1  neodymium iron borons and tell us about pressure
report back with your findings.
Speaking of experiments,  NOT addressing yourself, I just got done with my 10th experiment of biological effects on a NON LIVING SYSTEM (explain that in the 3rd edition) that will make peoples heads pop right off their shoulders.
See that?  Thats what experiments are for. I have reporting these findings to a few people, they fell backwards when they saw the pictures.
Now, go back to your non-experimentation son.
TheoriaApophasis
Quote from: MileHigh on July 19, 2014, 08:09:59 PM
For what it's worth, I note that after my two recent postings Theoria signed off.
Actually son, I was resetting my EXPERIMENT  (have 3 ongoing ones that take time and have to be reset)
You know, that stuff you dont do.
SeaMonkey:
Well thank you for stating that you don't think I am a "paid operative."  I don't want you to ever even slightly imply it in a future posting.
You are from the Navy and you must know the logic of submarine warfare.  I think TK knows it also.  Something like "Type I, II, and III" errors.  If you are in a submarine, you can't afford one of those errors no matter how slight the chances are because a mistake would mean certain death.
A few years ago I read a posting by some pulse motor builder and he talked about how many weapons he had and how he was willing to fight it out to the death with the Feds in some kind of "Ruby Ridge" scenario - for a bloody PULSE MOTOR.
How may postings have we seen from "crazy people" that show up for a day or two and say crazy stuff and then disappear never to be heard from again?  The answer is lots.
If you and other people like Captain Zero and people like him keep on saying or implying over and over that I am a paid operative or I am with the MIB then that can sink in with one or more mentally unstable regulars or one or more mentally unstable regular lurkers.
How many times do you see even "mainstream" regulars around here and on the Energetic Forum make comments that some medium to high-profile free energy proposition disappeared because they "probably threatened his life."   You see that ALL the time.
I can't afford a "Type II" (whichever) error.  I do NOT WANT mentally unstable people to read over and over that I am some "evil paid operative."
That applies to you, Captain Zero, E2matrix, and anybody that does it.  Any posting that has even the slightest whiff of implication that I am some kind of evil person in the employ of some evil entity will be reported.  It's time for this nonsense to stop.
