Quantum Energy Generator (QEG) Open Sourced (by HopeGirl)
Started by madddann, March 26, 2014, 09:42:27 PM
ACG
Secondary: 1590 Vpp = 562 Vrms.  Report showing 405 Vrms.
Primary: 14kVpp = 4949Vrms, 1.63App = 0.58Arms.  Report showing 4100Vrms X 0.5Arms = 22.8kVARpp / 2050kVARrms
When I read the report back when it was released I realized all the Vrms must have either come from the scope but not the screen shots shown or from an exported file that is later processed on a computer.  I stopped bothering trying to analyze after that.  With top notch Fleece The World open sourcing like this who needs CIA.  Secrecy has been a major factor in this entire boondoggle.  This is not a failure to present the calculations this is the refusal.  Never bothering to explain the math, whether cos of the phase was used, or automation by machine or software.  Even more disturbing was the 0 discussion of this by the be-do forum.  STILL waiting for that elusive fabled UK report of which James was hours away from self-running.
They are lost.
As the riders rode on by him he heard one call his name
If you want to save your soul from hell a riding on our range
Then cowboy change your ways today or with us you will ride
Tryin' to catch this devil's herd across these endless skies
aasaaaaaaaayyyyooooooooooo.......
Farmhand
I'm up to my ears in resonance here. I've got the HV tank, the output tank, I guess the primary is kinda resonant.
Now I've taken a TV yolk with about 100 turns on each half (around 3.3 mH each) then on one half I wound a 38 micro Henry primary
8 turns.
Which I am driving with a 10 nF series capacitor from the output tank AC, the secondaries are close enough to resonance as it is.
The Yolk transformer primary current and voltage is in phase and develops a higher voltage across it's primary than the driving voltage it goes up to 30 volts RMS and about 1 amp in that primary and it's in phase apparently. This transformer idling without tuning the HV tank develops over 100 volts p to p, each secondary can produce about 1000 volts p to p.
The secondaries are 0.5 mm wire and have not much DC resistance. I tuned the inductance of the coils by inserting some paper in the gap which reduced the secondary and primary inductance but was too much reduction, I need to make the coils a bit less than resonance frequency so that a load will reduce the inductance and bring the coils closer to resonance parameters.
So I think If I call the primary a series resonance, I have 6 coils in resonance at once.
1) The primary (driver). Series res
2) The HV tank (converts the primary excitation to clean sine waves) Parallel res
3) The output tank (taps the HV tank to output DC and AC LV) Parallel res
4) The ferrite core transformer primary (utilizes the LV AC from the output tank) Series res
5) The two secondary coils on the ferrite transformer. (produce from 100 to 1000 volts each) (self resonance) will
be tuned to loads.
Oh I've also got a small portable air core coil I tuned with a cap and put an LED across it as an indicator light to tell when the
setup is on and oscillating, that resonant as well.  :D
So I can take my pick when it come to which coil to measure.  :)
Next I'll setup an inverter circuit to run from the DC output and produce a 50 or 60 Hz output.
To think they can't take some output and rectify to run the DC motor or then invert it to get 60 Hz for the variac is a joke.
Either everyone that got burned will just shut up and write off the losses or they'll man up and hold hope girl and James to
account somehow.
By the way those QEG wave forms are very distorted sine waves. The RMS calculations for sine wave AC cannot possible apply
to those.
I'll make a drawing of my setup and show the probe points I use now and go from there.
Tinsel the 0.58 you quoted was the resistance in Ohms for the reactance I think.
If I get enough resonances all going at once from the one supply all the oscillating power OU will open a portal to the Quantum
and if I anchor myself to the bench when I get sucked through I might be able to drag myself back from the other side and tell
how it looks over there. hahahahaha
"Tinsel the 0.58 you quoted was the resistance in Ohms for the reactance I think."
Huh? No, I put the inductance and frequency you gave me, in to the reactance calculator I linked and it gave me the figure of X= 591 ohms or something like that, neglecting DC resistance, then I solved I = V/X using the voltage value you gave, and the answer was 0.58 amps.
Hah.... since you have all that resonance, I suppose I should post this here just for the record. I'm starting to play in earnest with my own "yolks" and the uQEG as driver.   ;)
http://www.youtube.com/watch?v=OadJX-BVUow
Farmhand
OK Thanks a heap again Tinsel, I just need to work out how to do that trick myself, I must have done something wrong.
Got coffee for video now. Ta for that as well.
Cheers
