Ultimate proof of Magnetic Vortex, free book and videos
Started by TheoriaApophasis, July 13, 2014, 04:20:12 AM
93RDELEMENT
Don't jump to quick TA THE RED IS UNIFORMED THATS A VACUM, IF ITS A VORTEX IT WILL HAVE A HIGHER TEMPRITURE IN THE CENTRE !
I WISH YOU ALL THE BEST BUT YOU WISH TO RETURN THE VALUES BACK TO A VORTEX AND THAT WILL COMPLETLY SEND MY WORK IN ANOTHER DIRECTION ! To many it means nothing to me its everything !
When you check out the charge from magnet to earth if your right than slowly there will appear a deeper red in the centre of the magnet and I mean the centre inside the magnet not the surface ! But give it a few hours or even a couple of days and the heat should rise if the vortex is there ! But again it will be a particle vortex not a magnetic vortex ! That's ok don't get to greedy you can only have what there is !
I am doing a modal to work out the mass hitting the magnet but that's only the dam mass not the group of particles or what order they will be in ????? I want bosons and gravitons alpha particles and nothing else ! Check everything including power lines there to many unknowns at this point ... Think it through more you must make sure no other radiation is hitting the magnet and that is not going to be easy .... Nothing like this is ever easy !!!!
I will not rule out dark matter as dark matter may be hiding between field line in the earths magnetic field but entropy and dark matter if confirmed is far more important than a vortex !!! You need a cheep high volt iron ball you can get one from maplins  !!! Anyone can make pictures but not anyone can make fundamental demonstrable finite calculations in physics and you need them we need them the world needs them  ...
At this point no vortex but a good vacuum ! That could change ???????????? but definitely no cog wheels wtf ??? why did you have to put them up ?????? r u nuts ???? stick to the particle fields you need to isolate its a very busy dense mass not a cog wheel ??? its not a toy !!!!
keep going I want the bosons and the gravitons I have a time line for the red to particle equation ! But if you are near a power linee forget it ! Go to a very high spot and do it in a heat box at night !!!!!! Good luck !!!!! and don't call me son ok son hahahaha
me
Acca
Thanks for the latest video clips of magnets with FLIR.. Those are very good looking images of the big magnet..
Will try that with liquid nitrogen and FLIR..  As you have made this possible.. Votrex has to have a higher temp that ambient since it's  a dynamic spinning sysyem.. That in it's self would be a Noble P......
Acca..
TheoriaApophasis
Quote from: Acca on August 15, 2014, 04:04:53 PM
Acca..
Ive got 2 dewers, I might try some LN2 if I ever find time
i made sure i was not getting thermal body heat reflection in the shots
93RDELEMENT
You need all the particles confirmed in the right order ! There is no easy work here !
me
TheoriaApophasis
Acca..
I was replicating this one tonight
https://www.youtube.com/watch?v=AJ7fMVp_O5s#t=10
using light to manipulate pyrolytic graphite over magnets
however their understanding of HOW or WHY it works is dead wrong.
it literally causes the pyrolytic graphite to "shoot" magnetism out the other side, which impels its motion TOWARDS the light and away from its own magnetic ejecta.
