Kapanadze Cousin - DALLY FREE ENERGY
Started by 27Bubba, September 18, 2012, 02:17:22 PM
0 Members and 1837 Guests are viewing this topic.
itsu
I went back from my nano pulser circuit to the kacher circuit again to be more aligned with the present Ruslan setup.
I changed the antenna coil from copper tubing to a wider solid copper 6mm² wire.
I trimmed my kacher secondary down (only a few centimeters now) till it resonates around 2.1MHz when connected via a choke to the antenna coil.
The kacher circuit is the most simple one, without being synced by the TL494 and powered by a very simple PS  :)
I can change the voltage on the Kacher between 12V and 24V without any effect on the resonance frequency of the kacher, so it seems quite stable.
My multi turn coil has a resonance peak also around 2.1MHz thats why i trimmed the kacher to it, but all my tuning up till now did not result in sync
between the 26KHz / 220V pp signal on the bulbs and the kacher.
Short video here:  https://www.youtube.com/watch?v=oftKB5YIHJw&feature=youtu.be
Regards Itsu
AlienGrey
Itsu, i have no idea where  you have the 15 volt zeners, but can you next time put 2 3.7volt basic to back zeners or so in the base of the bipolar switcher to zero, or protect it, or if you will exceed the base emitter voltage you will blow the device into the next life, you could look up the data of your device on the net. All the best, keep up the the good work ;).
magpwr
Quote from: itsu on October 19, 2014, 04:35:20 PM
Regards Itsu
hi itsu,
Have you factored in the 60th Subharmonics of 2.1MhZ which now your circuit need to run at 35khz just be in sync.
If you do a scope ref save base on your current setup at 2.1Mhz and if you are still sticking with 26.1khz.You will definitely noticed that both your waveform will not be aligned at all.
Maybe simple solution for you now is to slowly increase the yoke driver frequency to 35khz and observe if there is any increase in brightness without the nanopulse generator.
I have attached the harmonics calculator once more with your 2.1Mhz in it and please take a look at 60th Subharmonics as rough guide.
You do have the gift in producing elegant setup with the proper tools and  a nice bench but it would be pointless if you don't strictly follow the rules of harmonics as a guideline."Please don't be offended"
Ruslan did mention somewhere in forum do not use the spectrum analyzer for the multilayer coil.
At 60th Subharmonics if you got my point.
"Dear all this is not a science fair project provided if you realized this by now.I even noticed some of you don't even care about the spacing for the outer layer and simply wind this directly thick wire onto the coil.The reason for the spacing is to ensure the tesla coil resonance will not be tampered with if there is load eg:bulb.Provided if you are still serious in creating this device.This project is not about who finish first it's far more than that"
Enjoykin
New video from Ruslan Kulabuhov
http://www.youtube.com/watch?v=hpYj4YT_DIs
Я на стадии завершения . Предварительные опыты показали обалденные результаты. Осталось до собирать всё... Увы,но процесс медленный и требует много времени и мыслей. Пока всё хорошее не придёт , ничего не получится.
Enjoykin
Hi Itsu
Yes looks simple but is not simple - never been simple !!
I have forgot to tell - you should take in account the lenght of your coaxial cable. Several cm more or less and effect would vanish. Very tiny waveguide processes are here and very hard to catch.
You can use your lab PS but need to isolate your PS output with power diodes from other HV circuit like Ruslan has shown in his video. Also use any line filter from old computer PS and decouple both supply rails with respect to the ground. Bypass with lot of caps from 4700 uf/50V to 1kV 1nf bipolar capacitors. You will find all parts in old computer PC.  Also you can remade old PS to give you 24V/10...20A for use with generator.
Reg.
___________________________________
Hi Jeg
You are man of dreams.  :)
Answer for you is - just like shown i pictures. I put them in high resolution with intention. Analyse pictures - they will give you many answers. Resonant Capacitor is realy needed. His value is something more than 1uf/2kV. You can find it in old microwave oven. About measuring HV  - never put your oscilloscope probes on HV conductors or you will burn both. If you need to scope HV signals put old good rod antenna to oscilloscope 50 ohms input and tune sensitivity and time base. You will catch them easy at distance of several meters. this worth also for spetral analysers and frequency counters. 1m rod antenna from old radio will save your scope and other equipment.
Reg.
Hi Hoppy
16mm2 earth cable and 2m earthed cooper rod is Ruslan recommendation from interview.
Reg.
