GDS 3 KW generator runs on water
Started by ramset, October 25, 2014, 09:24:26 PM
ramset
Tinsel
thanks for stepping up.
I will call Mexico Too.
Chet
Thanks Grandma
TommeyLReed
Hi All,
I believe I said the same thing a while back, why was the turbine not spinning...
You know I have better things to do then play with who is right or wrong, I said this was a scam from the start after I did some calculation.
I think some people just want to believe in free energy, that they over look the details of input verse output of energy.
I'm done, won't be adding another post on the forum!
Tom
MarkE
In addition to all that tinselkoala has pointed out, one might note a couple of other things in the video:
Potter's first word is:  "Hola".
The video has available Spanish subtitles that include his 3000 Watts per hour idiocy.
There are some more questions.
What is the process at play?  Since this alleged process would completely revolutionize the entire world energy scene, why is he trying to sell portable generators?  Aren't there bigger fish to fry, like working with government, science, and industry to develop commercial-scale electrical generating stations?
What is the alleged base (primary) output of the native free energy process?  We know that we can take mechanical energy to power a generator to generate electricity.  Sometimes we generate the mechanical energy with heat, for example like when we boil water to drive a steam turbine.  So is the base output of the process heat?  Is the base output of the process direct mechanical energy?  Is the base output of the process direct electrical energy?  Is the base output of the process direct chemical energy?  If the base output of the process is direct chemical energy, then what is the form of the chemical energy?  How does the base output of the alleged over unity process eventually become the generator output, what are the conventional steps taken to go from <free energy process output> to <electrical output>?
How does the base output of the alleged free energy system relate to the requirement for water?   If water is "consumed" in the process, what are the waste products after the water is consumed?
When will a proper demonstration of the device be shown that proves the stated specifications of the device?  Typically we expect a demonstration where at least 10 times the stored energy in all of the batteries is expended during the test.  How will this type of test be implemented?  How will it be demonstrated?  How long will it be demonstrated for?  How will the output be measured?  How will the water consumption of the device be measured?  What steps will be taken to make the demonstration as convincing as possible if you assume that one is operating under the constraints of generating a video clip or possibly doing a live streaming event?  Will there be independent third-party witnesses that can attend any kind of demonstration?  How will any possible witness verification of the alleged system be documented?
Nink
Quote from: MarkE on November 02, 2014, 10:25:58 AM
He states that there is no other fuel source.  1:20 "Water goes in here, not fuel of any kind. ... This tank here four gallons should last three days."
The home page states:  "GDS is a manufacturing company in renewable energy. We have developed a portable water powered generator that creates a large amount of energy to run our portable generators that generate power simply by adding water. Spending money on expensive gasoline is a thing of the past. We have found a way to produce energy by adding clean tap water."
I have no doubt water goes in the water tank and not fuel in the water tank.    He keeps using that statement on facebook, website etc "We have developed a portable water powered generator that creates a large amount of energy to run our portable generators that generate power simply by adding water"   but what does that mean?
I get the feeling the way it was actually originally designed to work was you connect a hose, the water hits the pelton wheel,  charges the battery and then when the battery is charged you can use the power in the battery to run some small devices for a short period of time.
Interesting concept and probably useful for supplementing power using mains pressure water.  You place the generator on the roof of your house and connect it to your house water supply ( think there must be an exit tap underneath the generator), you also connect your garden hose to the tap on the generator.  If you had an external tank on the roof as well that held several hundred litres of water it would work even better,   You turn the hose on fill the tank while spinning the pelton wheel and charging the batteries. There looks to be all the parts necessary to do this.   The tap has an auto shut off valve he mentions the one way check valve in the video on the tap.  Now the water tank is drained and filled again if you turn a tap on in the house, The pelton wheels will once again spin as the water enters the generator and leaves the generator and enters your house, again providing power to the batteries.
I think that was the original purpose an energy scavenger using mains pressure water.     It looks like it was then modified and a 12V DC motor was added to spin the permanent magnet generator and this is where I get a little confused....Why go 12V DC  to PMG to Inverter instead of battery direct to Inverter apart from some noise and watching stuff spin.
